I have just followed Marks video on replacing a Balance Staff. All went great, fitted to check end shake and it was very tight.
I am assuming you adjust the jewel on the Balance cock and not at the roller end.
Not going to carry on with that until I'm sure.
Thanks for looking.
Is there any dimples on the main plate near the balance cock screw hole? If so then a previous repairer may have made an adjustment to the effective cock height using that method. If this is the case then have the dimples been smoothed down by any chance?
Hmmmmmmm, not au fait with "that method". But I shall look for Dimples after my nice cup of tea and home baked bread with home made plum jam...... :)
Hand a pocket watch with the same fault. When I stripped the watch there was a tiny slip of thick paper under the bridge. Without it the balance was too tight BUT with it, it ran great. I have read that when using this dodge the position of packings is important i.e packed at the rear tightens the balance and packed at the front lifts the bridge so loosens the balance.
Edited by clockboy
"That method" is not so uncommon with older movements.
Just looked through three movements on my bench I am working on and the third one had this done in the past:
You will notice in the hi-lighted portion that there are two dimples which have been created (using a graver or sharp screwdriver).
If these are done behind the screw hole (as in the picture) then it will effectively reduce the endshake. And it would increase the endshake if it is done in front of the screw hole (closer to the balance wheel).
I knew a watch repairer that would use paper to achieve the same result. Also you will find that some watch movements will have a metal shim between the cock and the mainplate - Sekonda used to do this.
Right.... had a look at it and no dimples, or evidence of being filed down. This method does seem to me to be a bit of a, "Yee Haa" method.
I would of thought that raising or lowering a jewel would be the correct way to go. On saying that, I am, at present also working on a Russian movement, which has got a metal shim, which has been professionally made and is a perfect fit to the shape of the balance cock.
Is it not correct to raise or lower the jewels? In my case the jewelling is not of the shockproof type.
Is this what the Bergeon rounding tool is used for ??
Are you talking about Bergeon 5482?
If so then no. If we are talking about 1/100mm or 2/100mm reduction you will be working all day using that thing. It is useful when you reduce the pivot length using an arkansas stone - finish with the rounder if needed (using some diamantine mixed with oil in the cup end).
How is the endstone mounted?
Yes it is the Bergeon 5482 I was looking at.
Therefore I presume it is used to shape the end of a pivot/balance when being made.
So many failures I have lost count with this, but this tool might help.
I personally didn't like it. It is very slow to use. Much prefer rounding using a Jacot.
Jacot: about 2.5seconds to round off a pivot (plus setup time).
This tool: after 20 minutes I just got the Jacot out :D
Decided to go the "Shim" route, as twatting the plate seemed a bit wrong. Also I would think that the indentations, front or back, of the screw holes would cause the Balance Cock to be on an incline, maybe causing the jewel to be out of alignment vertically.
Anyway this is what I have done.............
Shim made from edge of tablet strip......
Cut out with scalpel....
Holes for screw posts.....
On the plate....
All done and running lovely.....   :)
When I started this movement it was a right rust bucket, anything that could rust had nearly. the barrel was a mess and the keyless works were a homogeneous mass of rust. So after a couple of weeks of intermittent work it is now back working, just got to see the timing situation.
This was my first attempt at changing a balance staff, hence this topic, it has gone very well with the help I have received and I therefore thank you for your input.
This could only be done after studying Marks fantastic Vid's.
I'm well pleased for you, it's a great feeling when you are successful when into new territory. Keep up the good work.
Nice work Legarm !   do you have a pic of the finished watch.    :thumbsu:
Just the movement at the moment. Waiting for the right dial and case to come along.......
All the Russian watches I've tinkered with use shims.
When you get the dimples or scratches i always thought this was bad practice as the previous repairer hadn't got the correctly sized staff and modified the watch to the incorrect staff as opposed to the other way round... If that makes sense!
I agree,
I've seen similar practice on larger engineering jobs,  eg ;  to tighten up a loose bearing track in a housing, etc,  I've always considered it to be a bit of an ''educated bodge''.
I agree,
Nothing educated about it!
Yup - and its amazing how often you will see it on vintage movements and modern ones as well.
I suppose some customers would not want to pay for the amount of time a watch repairer would have to spend to do the job properly, so the quick and dirty approach is adopted.
The problem is - the next watch repairer who works on the watch, is the poor bugger who has to deal with it.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
