Hello from Sussex UK
carlos123
Hello all,
After a bad experience with Rolex servicing several months ago, I decided to take a look myself and have a play. I have an engineering background so thought this would be ideal.
I'm currently just playing with odds and sods bought from eBay in my voyage discovery and hoping to have this as a hobby and possibly make some beer money - if I can master it....
Thanks for letting me join, I shall be looking through the forum and probably post some questions soon.
Cheers
Carl
Welcome to the madness that is the watch hobby. Always something to learn. Great hobby.
No offense intended. Your Rolex is not the watch to learn on. I'm new to the group, but have done enough to know that you WILL damage things when your learning, it's far better to damage a $10 Timex than a Rolex. You can get to the Rolex later.
Was your Rolex serviced by Rolex? What was the bad experience?
Hello all,
Cheers
Carl
No do not learn on Timex as their movements are very different and very difficult to put back together.  Instead get a few 17 jewel movements to learn on.  You will find the engineering of the parts to be much better and once apart they go together much easier.
Pocket watches are another good learning movement because the parts are big.
Good to know not to use Timex. I'm at the stage where I would like to learn to service my own watches. I'll skip buying Timex to learn on. Would a 6497 movement to a good choice?
I concur on the timexes !you can buy buckets of old russian vostok and raketa movements for nil.Parts interchangeability is fair and they work the same way as their western counterparts. Out of a dozen you might get 3 or 4 to actually work,if not, not much lost.
Just now, yankeedog said:
I concur on the timexes !you can buy buckets of old russian vostok and raketa movements for nil.Parts interchangeability is fair and they work the same way as their western counterparts. Out of a dozen you might get 3 or 4 to actually work,if not, not much lost.clean them with mineral spirits and lubricate them with motor oil. they don't mind.
odd that you mention Russian watches, as it was a raketa that I first had to correct an overbanked balance wheel.  I had dropped the watch after giving the case a polish and noticed it stopped working.  When I looked inside I saw the balance would not swing and I thought there is now way I can correct.  But, was amazed and how easy it was and only because the parts just slipped right back into place.
As I Timex restorer I can say without hesitation that is not the case with a vintage Timex.  Typically the issue there would be the pallet fork has been bent out of position.  To change one is like trying to keep Mercury from slipping through your fingers!
Hmmm I like that line, maybe put it on a t-shirt!
    • Great piece of kit. Is that a tin of oats? I see it looks like to be a macgyvered power drill. Nice. How did you control the speed? Don't tell me you hold it while it does all the cleaning cycles? Where did you get that nice mount and stand for the drill? Why was there a need for a step down transformer for 230V to 143V?? Does the hair dryer not get hot enough to melt the shellac on the pallet fork and such? That's a repurposed oven timer right? What's the white appliance? Cool.
    • I had the same issue. C to CS adapter: https://www.amazon.com/gp/product/B01FY70S4G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Not sure where you're located, but your amazon link looks like a US market one, so that should work for you. I even got a 4-pack; one for each power, plus one for @gpraceman (did I give that to you already?) to complete his set. I'm not sure having one for each power is worth it, but they were cheap.
    • Thanks OH. The name is William Burroughs, Chippenham. The brass plate is 12" across but the dial itself is 11.24" diameter. The case appears to be Oak (the hood remains at my friend's house). I can see many suspension springs on line but don't know what this one's specifications would be. Re Rochard's comnent, I could see how a chain loop could be used manually to turn a toothed day wheel but this one is toothed on the inside circumference!
    • 1914 then lol This is a very difficult old watch for a beginner to tackle,  the case screws suggest it comes out from the front so the broken one is not going to prevent the movement from coming out now that it is broken.  The screw that you point to is a dial foot screw that only needs half a turn to release the dial foot from the screw's sharp shoulder that cuts into the foot. But honestly i would bag it up for another time until you are ready. If you lose anything from this while taking it apart and you almost certainly will, you may well struggle to find a replacement, seriously this is too sentimental to mess with just yet. Beginners perception of what is involved can be way way off what is reality.
    • 👍Thats what i like to hear fella  , someone with some blood in their veins 😄.      " TAH- DAHAAAA "⚡️⚡️☄️  🔥  There's never a decent imoji when you want one  🤷‍♂️ If you questions , which I'm sure you will have. 1. Yes i could well be one card short of a full pack.  2.  Yes I'm serious this IS my actual set up 3. Dont forget what i said about laughing at it.  Fire away I'm  all ears,   🤔 eyes...........whatever 🤷‍♂️
