ETA 2832 Automatic Technical Sheet/Help
This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel? -
It shouldn't be attached The pinions look independent of each other, not in alignment, but the clip is bothering me or have you just placed that on the pivot end? -
What this extra disk next to the pinion? Thats not part of the assembly -
It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position. So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
