Strange Timegrapher display
mikepilk
I just put a Revue MSR T43 on the Timegrapher and I'm getting this odd display.
Visually it looks to be in beat, and the amplitude looks good.
I don't understand how you can have two close traces and a large beat error. Don't they come from the same signals ?
I can now answer my own question - I should have done some more searching.
I found the thread   3407-single-line-and-57ms-beat-error/
It appears that with a Weishi 1000, with a beat error of about 5.5 ms, one plot rolls-over and plots close to the other, giving the false impression that they are close.
I followed the advice in the thread, and moved the stud arm clockwise - problem solved.
It goes to show that you can have a huge beat error, with relatively little effect on amplitude.
I had long educational lessons from @JohnR725 and he mentioned this "overlapping" problem when "way-out" of beat. My Laco's are statically in beat, but the software showed 9.8 ms ...... We are still not sure what's going on; software or mechanical....
I read the thread you are referring to and it's amazing to see how many times JohnR725 stepped in with his time-machine knowledge .....:thumbsu:
Anyway, you found the answer and solved the problem ;)
Edited by Endeavor
there are several important rules to remember when using the timing machine. First pay attention the numbers and the graphical display and make sure they agree plus visually look at the watch and make sure whatever the watch is doing agrees with what you see on the timing machine. Then my favorite phrase for timing machines is garbage in garbage out. If the graphical display looks like total crap the numbers will be the same. Is not like the timing machine can magically look at the random dots and produce a rate or an amplitude that is going to be correct.
I did a visual check that it was in beat, and the amplitude looked good, which is why I was confused with the display.
Another lesson learned.
    • It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it.    I'll get a replacement from eBay.
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
