PLEASE HELP ME TO IDENTIFY THIS MOVEMENT
You have a rocking bar set and wind design chief, still usable for identification. We just need the plate diameter now. -
Thanks Geotex, From what I can see the keyless works on mine is completely different to those in the photo, I had a bit of a Google and it looks like it's called a rocking bar?? I can't seem to find a single match online though. As far as the setting lever screw goes, you've just explained what I'm doing wrong and why it was probably left out in the first place. It needs to go in before the bridge 🙃. That's why the hole isn't big enough because it's designed to be smaller to stop the screw falling out until the bridge is removed. Thank you for that! I'll remove the bridge tonight and get it refit.
By LittleWatchShop · Posted
