My opinion on automatic cleaning machines
jdm
I fail to understant what an auto machine does better than manual or U/S cleaning. All what it does is heating the fluid and doing a little of shaking, plus of course chaning jars for you, oh the solace.. No doubt looks impressive to show off.
When I was, a watchmaker, I would clean many at once in an auto machine. Never need to watch and move the thing from one jar to another. It gave very good results. It left me time to get on with other things like cleaning the cases or fitting a new glass. Or if I felt like it a walk round town, come back in say 20 minutes and its waiting for you. After having an automatic, you will not want to go back to a manual one.
Agree with oldhippy. I miss my L&R varimatic a lot, cleaning was an absolute breeze.  It is broken & I will have to fix it myself (when time).  I now use a Indian made cleaner (Janter Pearl)  which surprisingly gives great results. But it is manual and is just not solidly built. The cleaner oldhippy has found is a lovely machine but I have not got a limitless budget.
Now when you look at the audience of this forum 70% are hobbyists than never work on more than a watch at the time, and never rush things. For them, the money and space taken by an auto machine is better spent elsewhere. Add that these old device have an habit of breaking easily (as the many threads here demonstrate) and there is only one guy in the UK that will will wok repair them, and you have another potential headache saved.
I agree. However I do find the ultrasonic cleaning method time consuming and inefficient. The parts seem cleaner and are dry when the machine has finished when using a pro machine without any fuss. It is down to budget and space.
Cleaner than from an ultrasonic machine having been just shaken a little? Sorry, that is hard to believe.
And since oldhippy likes to share Ebay links for these machines I have merged these threads to keep the discussion in a single place.
5 minutes ago, clockboy said:
The L&R varimatic not only washes the parts it also ultrasonic cleans as well. The parts come out clean and sparkly with a breeze.
I have looked at the L&R website and looks like they have dropped the automatic jar changing and are producing only U/S machines. http://www.lrultrasonics.com/industries/jewelry/
Maybe the professionals have found having to change solutions manually is not that a big issue after all.
I was told by the guy who re- furbed the L&R that the vintage machines Ultrsonically cleaned in all three jars but the new L&R’s only ultrasonic in the first jar. Changing the fluid was not an issue as it lasts for approx 30 watches.
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
