omega 26.5 t3 main spring issues
Hi guys,
I have serviced and repaired my fathers broken omega with a 26.5 t3 moment I have managed to get it all back together, but can not get the main spring to wind, I have tried putting it in two ways, but the barrel just moves with no spring wind at all.
I have replaced the arbour and that hasn't seemed to help either. after a while of winding the keyless works seem to slip as well and start moving the monition works which is also frustrating.
does anyone have any pointers of experience with this movement?
Many thanks
Andy
Do you test the barrel alone by winding the arbor to see if the mainspring had hooked on correctly? You could have inserted it the wrong way around for example.
Another common fault with assembling keyless works is to insert the castle wheel the wrong way round as the teeth have different profiles on either side.
Thanks guys, Have two barrels, one with an old spring and one with a new spring, have tried inserting the new spring both ways, and have tested that it hooks, it does, it should wind..... and nothing is working.
The keyless works, work well once I have stripped them, but after trying to wind the spring for a while the movement works rotate when the stem is turned. which would cause the hands to move. I checked the gear on the keyless works, no bevel, or decreeable profile,  but I have also tried inserting it both ways with no difference. Im dreading getting to the balance as this is also bound to be a real pig, the way this one is going.
I feel like I am just going around in circles with this watch and its very frustrating. I feel like I have taken this watch apart a thousand times now.
Any other ideas as to what could be going on?
  • 4 months later...
Hi yes have tried this, but it still won't work when the whole watch is back together in one piece. it was my late fathers watch (he just passed a few months ago) orginally I was repairing it as a birthday gift, but now want to get it back and running so I can wear it to have something of his with me most days.
So, first things first: have you confirmed that the barrel arbor is hooking the spring hook by holding the barrel stationary and turning the projecting barrel arbor with tweezers or a pin vice?
Edited by rodabod
I'm working on one of these at the moment - just fitted a new balance staff today.
I always take a pic of the mainspring to see which way it winds- this is the correct way
I have other pictures I took during disassembly should you need any help.
It's a straightforward movement - there's nothing unusual about the keyless or motion works.
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
    • Definitely worthwhile, if you are working with old watches - just be sure it's an actual Geiger counter, not one of the vast range of scam/fake "Radiation detectors" on ebay & amazon etc. that detect RF or static electricity...   In the mean time, I'd put the dial and hands in zip bags & wipe down the work area with a damp cloth to pick up any dust, then discard the cloth. The emitted radiation from radium lume is not normally harmful - but inhaling or ingesting a single particle of the material can cause serious long term harm, so do take care with it.
