Inserting Pallet Jewels
The exit jewel came loose so I ended up pulling both jewels and removing the shellac. However, I'm having one heck of a time trying to reinsert the jewels. What is the preferred procedure for doing this?
It looks like in the photograph there is still shellac on the stones? Alcohol will dissolve the shellac they will have to be absolutely clean than they should slide in. They definitely will slide in because there supposed to be movable in other words there adjusted to an exacting position. It's why they use shellac under heat the stones can be moved.
Then the modern version of the tool showed above can be found at the link below. They do show up on eBay from time to time at several hundred dollars if you're lucky new price with the heater very very expensive.
http://shop.bergeon.ch/Catalogue/PDF/1092 C D.pdf
I joined today because one of my pallet jewels somehow got tilted skyward and was not engaging with the escapement wheel and a search brought me to this thread. I gave the wayward jewel a nudge and it seems to have rotated back into place, but I'm going to take a better look tomorrow when my USB microscope arrives. There's plenty of shellac still in the gap so maybe all I'll need to do is heat things up a bit. I'm not sure if its current position is the way it came from the factory or not, but I'm hoping a better view will clear that up.
Have you read this yet? It's about the only information I could find about setting pallet jewels. http://raulhorology.com/2012/08/eta-6498-escapement-fitting-the-pallet-staff-and-jewels-setting-depth-of-lock-and-run-to-banking/
My hair-brained ill-informed plan is to simply heat things up holding the tip of a soldering iron close to the loose jewel while observing it with a USB microscope. When the shellac flows i will remove the heat and hope for the best.
Yes, I came across that link the other day. I used a piece of wood to make a "staking  block" similar to what's shown in the article. Still, trying to fit these small components is a challenge.
There's another option for something like this and that is dissolve the shellac ain alcohol and make a glue. Then you can just put a small amount on the fork let the alcohol evaporate and it's fine. This also works if you think the stones are loosing you don't want to play with heating them up you just glue things back. Then because this is still shellac if you have to move things around later on it works just fine. Versus some other inappropriate method of gluing the stones in.
3 minutes ago, audiomagnate said:
70% isopropyl alcohol
So the alcohol I have is labeled denatured alcohol. Says that it's for thinning shellac, cleans glass and metal and Clean burning fuel for Marine stoves. Nowhere on the canned this say what sort of alcohol it is. Googling the product code gives me both links below the second link actually looks like they can I have. Then I was wondering if they change the formula but I saw somebody already asked that somewhere else and apparently it's still what it's supposed to be which is denatured alcohol. Apparently that's an ethanol-based alcohol with a little methanol to make it Bad at least for drinking.
So you can try if your alcohol doesn't work and I'm concerned about the water content. Then hardware or woodworking store as shellac is used as a finish. And what does Google I was reminded you can get it pre-mixed with solvent zero idea as to whether it's suitable for our need and unfortunately even the tiniest of canned is a lot. Plus you can buy the shellac as flakes for wood furnishing and that does work for watch repair it just comes in a really big quantity
https://www.amazon.com/Klean-Strip-GSL26-Denatured-Alcohol-1-Gallon/dp/B001EMB2A0
https://www.amazon.com/Klean-Strip-QSL26-Denatured-Alcohol-1-Quart/dp/B002MBX2QE/ref=pd_sim_60_3?_encoding=UTF8&pd_rd_i=B002MBX2QE&pd_rd_r=0a2270f3-7cc9-11e8-ae7d-27beeed8d987&pd_rd_w=6e08C&pd_rd_wg=xEPlz&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=7967298517161621930&pf_rd_r=PBR09Q93MVQBRCKBCARV&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=PBR09Q93MVQBRCKBCARV
Other options for holding your pallet fork images attached. Commercial tool holds the fork down. Then a lot of times I'll just use the brass plate and has a variety of holes. It was just simple and easy to make and the reason for all the holes was it can also be used for bluing screws.
Upon closer inspection, it looks like the gap is not supposed to be there. The jewel in question is the one on the right in the first photo and shown in closeup in the second photo. The third photo is of the properly seated (and lubricated) jewel.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
