I was very taken with an article in Mark's blog on a Hamilton Intra-Matic watch that he'd serviced - one with a Buren calibre 1281 micro-rotor movement. So - some days ago, I found one on the German, Ranfft "bidfun" auction database, put in the minimum bid - and came back from Devon today to find I'd been successful in my bid. (Even on holiday, "watchitis" continues apace...).
Lovely movement, and I'm looking forward to getting this one.
Excellent looking watch, very clean by the pic, and to me a unique type worth of your wonderful collection! Sometimes I think "watchitis" is not too bad when you find gems like that one! Way to go Will!...and welcome back from vacation!
wow grats on that wonderful find   micro rotors are really cool that movement looks pristine
Sincerely
Jim
Well, the watch arrived today - ticking away like a good auto should - and I've had it on test for two hours or so on the wrist. So far, keeping nice time. I've appended my own recent pic of the movement, which looks beautiful. I'm not a huge fan of automatic movements, mainly because the rotor obscures the details of the movement, though I do have Seiko and Mido autos, but this little micro-rotor is the bees knees. I wonder why they weren't as popular as the more conventional and larger rotor-driven movements. Perhaps the servicing was more of a problem - perhaps they aren't as efficient in maintaining a power reserve or they were more fragile. Who knows. Anyway, I love all 30 jewels of it!
Edited by WillFly
Hi Will,
Just turn the screw on the balance wheel, it is a cam that will do small adjustments with timing. Easy on it though!
I believe you were talking about that adjustment or maybe I misundestood?
Edited by bobm12
Hi Will, for course adjustment, push or pull the arm with the guide pins, and for micro-adjustment turn screw. The other lever that holds the hairspring stud can be moved to adjust beat.
The movement has a self-winding gear with direction switching, which works by a pinion floating between two huge jewels. This from the Ranfft database...
Good morning Will. I found this article http://people.timezone.com/library/archives/archives631988314105468750 on the the Buren microrotor movement that gives an excellent description of its workings.
In my previous answer regarding regulation I only mentioned the micro-adjustment for fast and slow. Having read this article, the screw furthest away from the balance pivot is for micro-adjustment of the beat.
Thanks for that, Geo - just read it, and a fascinating article it is. The breakdown he shows is of the early, 17-jewel model, and he mentions how he'd like to get his hands on the later, 30-jewel model - which is what I have. I'm going to copy the article into my watch file.
The thing that really attracted me to the Buren 1281 was just the sheer beauty of its design and looks - and it's even more interesting to see its technical description.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
