feintaster tool .
rogart63
Well I have one and it is very useful and accurate the most useful function is the adjustable table for putting small parts on it makes measuring jewels easy, they can still be bought for around £350 new, so as long as its functioning £85.00 is a good price they usually fetch £150 to £200 its the sort of quality product you only need to buy once useful but not essential.
I have one that I don't use much, but it is very useful when I do. The table is something that is really needed in my view, I also have a bench micrometer with a table and I use this more than the feintaster.
What I like about this is the soft closing of the anvils, very good for delicate parts. £85 is a decent price if condition is good.
Stephen
I'd probably replace the whole base plate.. My feintaster looks the same, but with blue velour. I always had mixed feelings about the stuff, since it's a dirt trap, and I'm not sure if it's that great at trapping dropped parts (which I assume is it's main purpose).
I wonder what would work better as a replacement.. Leather, like you suggest? Some sort of silicone sheet? Chamois? Anything that stops the part from bouncing.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
