Longines Quartz
I think that's a ring holding down the movement. It may be pulled out to disengage and free the movement but you might need to remove the screws mentined before, the 2 on the very edge (maybe at 11 and 5?). The "indentation" on the ring  (12 oclock ?) is to pull it out or so it seems.
Once the ring is removed, the opening will be wide enough for the movement + dial to come out.
Again, I'm speculating here, proceed with caution.
I'm new and know nothing but ill give it a try. Can you remove the winding mechanism then twist the moment with the transistor area up as there looks to be a space their that it may allow it to slide up? Just watched Mark's video with the Rolex movement and turning it seems the same here.
Just a thought !
I'm still convinced that it comes out the front and that the screws will have to be removed to remove the bezel and crystal. I only hope someone who does know tells you before you damage something.
I'm with Geo on this one. It's quite possible that some of the screws are decorative and that others hold down the bezel. Worth a gentle try, perhaps.
I think Will is on the right line. Its either the screws surrounding the bezel or the two screws @ approx 11 o'clock & 5 o'clock that are holding the movement and spacer. If the watch is rusted it might not be obvious that it is ready to come out when these screws & stem are removed & GENTLE tap might show results.
I believe i had one before for repair and if i have good memory,the bezel was pressed in with a gasket.
The screws were only decorational ones
So try the knife way i believe you will succeed
p.s: sent from my s****y phone so sorry for typing mistakes
Where have you been hiding Emso? This is what we have been waiting for!
Besides the job, tapatalk did not inform me that there were new messages in this forum.
So i did not know that someone posted
Br
Emso
P.s can someone tell how can i stop receiving notifications on e-mail as my inbox is full from this forum
p.p.s: sent from my s****y phone so sorry for typing mistakes
Emso
Hello Emso.  Just had a quick look re emails,  If you click on your name (Top right, near sign in, sign out) amongst the options is my settings and amongst those is notification options to turn email notification On/Off.  Hope this helps.
Edited by autowind
I have looked at this again & again  and I can not see any reason for the screws other than removing the movement. They seem to have a washer or lip and therefore I conclude that they are for holding something, either the movement or a spacer ring.
I agree with Geo & emso. The only info I have found so far is that Boley quote a bezel gasket for this model, this combined with the movement holding screws strongly suggests a front loader.
Hello all. Back from vacationing at Cape Cod and I have good news. Emso you have a good memory. The movement came throught the front. The screws are only for decoration. See attached pictures. Hopefully I can get it running.post-310-0-04817300-1413654451_thumb.jpgpost-310-0-31710500-1413654473_thumb.jpgpost-310-0-41065000-1413654489_thumb.jpg
Hi All,
   Ok I have been looking at this case several times and it just doesn't make sense. Why would you have a top loader and then have to take the back off to remove the stem? Most top loaders are designed so that there is no back to remove. Anyway I see that it was indeed a top loader but would have confused me as well.
Charles K
Edited by CKelly
Hi All,
Charles K
Not uncommon on the various watches I have worked on, both Swiss & Japanese. Mostly due to a large dial on small calibre, but not always so.
    • can I ask why you're not happy? did you notice that the acceptable low 24 hour amplitude of this watch is 160°? is there any possibility that a watch company could manufacture a watch that could actually run at a low amplitude and keep time? so if they can run at 160° at 24 hours and keep time then they probably would keep time at 240° which yours seems to be doing? then if you're really unhappy with this I would recommend purchasing an original Omega mainspring. Just because the aftermarket have numbers like an Omega mainspring it doesn't mean it's the same thing. Then I would also recommend replacing the escape wheel and the pallet fork. This is what they do in the Swatch group service center if they are unhappy with anything on the other hand they have an infinite supply of spare parts.
    • That was reason for asking for mark's input, i wasn't sure if going ahead with dealing with the contact information would be particularly well received. @oldhippy thoughts ?
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
