Hi All
This is an EB 1575N Roskopf pin leverthat I'm learning on. https://17jewels.info/movements-en/movements-e-en/movements-e-eb-en/417-eb-1575n.html
I don't see where the setting lever attaches.  In the pics below, it's simply resting on the stem.  The link above has a similiar pic.  As far as I can tell,  the dial is the only thing that goes over it.  You can also see that there's a threaded post that's attached.  Wouldn't something screw onto it.
All comments welcome.
Charlie
Not sure if I'm understanding your question? Then you don't quite have things correct in the picture. The detent the protruding pin goes into the slot of the stem not where it is now. The setting lever goes into the notch of the clutch wheel as opposed to where it is now and then everything should be fine. Sometimes on really cheap watches they minimalize the components.
Is this how you tried installing it ? Have you encountered any issues ?
Edited by Chopin
The screw on the setting lever is broken of. You need to find a new screw and it will probably work as it should. The setting lever arm should rest on the clutch wheel . Like in the picture. No need for a setting lever spring on this movement as it seams.
It didn't occur to me that the screw was sheared (beginner here).   Under higher magnification I can see the shear in the 2nd pic.
It looks like the it should be screwed into the hole highlighted below. Is that correct?
Is a pin vice (which I don't have) the optimal tool for removing the broken screw?  Finally, Cousins UK sells "All Kinds Mixed Screws".  Is this a good place to start for a replacement?
Many thanks to all!
Edited by Lc130
A pin vice will do yes. Can try with some tweezers but the screw might be too tight.
Screws shouldn't be a problem to find, that cousins assortment might help...
Many thanks to all!
That screw should be easy to remove as you have something to grip. A Knipex endcutter or similar . Or a small bench vice. As for the screw i think need a setting lever screw. But maybe can get away with a normal screw in the right size .
    • As a fellow newbie who's made a bunch of mistakes over the past year or 2 I'd like to offer my experience. I didn't start with a new practice movement, I started with 1970s Tissot that I loved. If I could do it over I would still use a vintage watch for my first movement. I wouldn't, however, chose one I cared about or that was expensive. It also had a calendar complication- dont do that. I learned a lot about part compatibility and movement families right away though! Emmy watch and Ranfft are great resources for this! I would start with the Benrus and go ahead and find a parts movement right away YOU WILL BREAK AND LOSE PARTS! Get good tweezers, it's much harder to handle tiny springs than YouTube would suggest. And be extra carful, pivots don't like to be forced into jewels - bridges are a real pain in the ass at the start. Don't be afraid to use your bare hands to hold parts/bridges and handle the movement. Finger cotts can come later. Be as carful as possible with hairsprings, this can ruin all the fun!  Buy a cheap demagnitizer. For me, I think its fine to buy cheap tools in the beginning and replace as you go. But some things I wish I'd have spent more money on right of the bat - TWEEZERS and Rodico (don't get the fake stuff). There's a great thread here on Chinese tools. I used a cheap digital microscope for a long time. I got quite good at working under it even with no depth perception. It's probably better to just use loupes but I think it helped me be more mindful and it was great for inspection. I now have a stereo microscope and if you get really into this hobby, it's a must. I cleaned everything by hand in the beginning. This is great for getting familiar with each part and learning to inspect for faults. Peg your jewels! I still hand clean a lot of parts before the ultrasonic. I still use JUST Naptha and IPA and I think thats adequate for my hobby purposes but maybe I'll have moved up in another year. I swish the shellaced parts in IPA for a few seconds to rinse (don't tell anyone). I used to dry each part on a sheet of paper with a puffer. Again, this is good for getting to know each part. I now dry everything in a food dehydrator. Im not going to give any advice on oil because thats suicide. But... until very recently I used just mobius 8000 and Molycote DX for everything. I dont know if I would do it differently If I were to go back but its definitely cheap and it will teach you how to apply oil.  Take a picture after every move even if it's just scratching yourself.  Wind mainsprings by hand until you decide you like the hobby, spend that winder money on tweezers and parts movements. This place is great, there are a bunch of incredible KNOWLEDGEABLE guys willing to help you. Unfortunately, this is as much as I can help, as I'm nowhere near their level.  Oh... and buy a big magnet. Still one of my favorite watches and it reminds me of all the broken pivots and pinged springs every time I put it on.   worth every penny.
    • @RichardHarris123is that a pony chrono pusher?
    • The most important watch repair ever.  No not a long lost John Harrison or the like but my three year old granddaughter's.  £2.99 but "Grandpa, my watch is broken, can you fix it.  How could I say no?
    • Omega Cal 1337 Quartz Movement - I repaired (or so I thought) my first full movement from spare parts from not working movements. Everything seems to be running smoothly except its running probably 5-8 seconds fast per minute.  Any thoughts?
