I have this gorgeous 18k gold 17 rubis watch. It hasnt been working for a bit but i never bothered to look at why.
I looked tonight because I was going to list it for sale. And i found the really thin coil balance spring has popped out. I dont want to be paying to have it fixed. I'm pretty good repairing things once ive been given instuctions.
Is there anyone who may be able to help me? Pleaseee
Do you have watchmaking tools ? (for this one you're going to meed a lot more than a loupe and screwdrivers)
Do you have experience with repairing watches ?
This job is pretty difficult so a beginner can't/shouldn't do this.
Sorry to say but that is beyond repair. That hairspring is way to damaged. You will need a new balance wheel with hairspring,
though I hate to hear "that can't be repaired" ,  BUT,   this repair is not FEASEABLE.   could cause headaches,  the easy way out is BUY NEW.  vin
Basically you're going to either have to buy just the hairspring and have it replaced or the entire balance complete as it's called...
Given that it's a vintage watch it's not going to be easy. Most likely hairsprings from other movements might fit but it's not gonna be easy to find the one needed.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
