Smiths Empire RAF 1943
p2n
Hi I have just got one of these clocks from my elderly farther, it is in good working order. Never had one, simple question what should I do to keep it wound up...? Wind it every day, wind it once a week, I want to make sure I don't over-wind it etc. Any advice would be welcomed.
On 5/21/2018 at 5:07 AM, oldhippy said:
I never used that type. This is the type of winder I had.
I just took out my English pattern winder to take a look at it. I've never actually used it before as it looks too small. I don't know if this is a clock winder or just a pocket watch winder on steroids.
I took a photo of it next to a clock barrel that I was working on just for comparison. I'm not sure how to place a containment ring on the spring when using this type of winder.
18 hours ago, watchweasol said:
I would think its an eight day so once a week would do.  Can you post a picture of the movement  .  I should think also that it will require a service to get the best out of it.
Thanks, the movement is the same as the one posted earlier the EMPIRE 151.
1 hour ago, oldhippy said:
This is a good video for you about the winder.
That looks really scary. Just using a long nose plier to hold the end of the spring looks like a really unsafe practice. Have you ever let the spring slip out of your grip while adjusting the barrel?
Thanks OH for teaching me this technique yesterday. I just used it to remove a damaged clock spring because the eye of the spring had a tear and was on the verge of total failure. Had I used my usual method with my Webster winder, the hook would have torn off the eye and sent the spring flying off. You saved me an eye and probably some fingers. ?
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
