Vintage / antique clocks
Thank you for your reply and for the advice. Let's see how it goes. Best regards, gerardo.
Little chance for a direct transfer to work, even if both movements are of exact same caliber. If lucky you might have a close match, in which case adjusting is done by adding or reducing balance weight. Otherwise its down to assortment of overcoils and hope to find a close match. Welcome here and good luck.
I think they are the same, but maybe I am mistaken. Attached is a picture with the movement that has the torn spring on the left and the movement I have found for spares on the right. Thank you for your help!
Welcome to the forum. Are they the same movement?
