You have a gold plated case and stainless steel back (two different metal), this tells me the back is removable. The one piece cases, ( which I think are called monoblock ) tells us it has to be a front loader. I would place a piece of 1/2mm thick cardboard on the " hole" and pry the back plate with screwdriver, the cardboard will hopefully keep the case from getting scratched. The movement in your watch is likely to be a rotary in-house, thus collectable. Rgds
Is this a not enough hands problem? Maybe trying to pinch the stud side in a vise? Tack it to one side with a drop of hot glue or gs cement or a tiny bit of folded painters tape to hold the stud ring while it gets pinched in place? Would need to have the top side of the stud protruding to accommodate the regulator side. I suspect you wouldn’t need much pressure to keep the stud closed while you stretch the regulator ring… …or maybe an oiler sized drop of glue will keep the stud ring closed, fit the regulator then dissolve the glue? Here’s my vise..
You need something like this. https://www.cousinsuk.com/search?searchTerm=C32766
