Is My Pallet Fork Misaligned?
One of the problems with being new to watch repair is finding nonexistent problems when you cannot spot the real problems. This is where you have to be very careful not to jump to conclusions and runoff fixing things that may or may not be the problem.
I understand what you're saying but how does it relate to this specific problem?
5 hours ago, Lawren5 said:
I haven't developed a trained eye yet but to me the guard pin looks fine. It's the lever that looks bent.
So bent lever that would be a new one sort of. If you work on hundred-year-old watches like I do that is a possibility but on a modern watch that hasn't been played with the last hundred years it's not impossible but it's extremely unlikely. So my wild guess would be it's something else perhaps.
So I don't suppose you're pallet fork is either bent up or down is it? So one thing that isl really easy to do is break off pivots on the pallet fork. From your pictures it looks like the upper pivot is still in place perhaps. If one of the pivots is missing the fork would be either bent up or down possibly if the pivot is bent then the pallet fork may appear to be up or down. Otherwise the guard pin looks good except Looking straight down it looks almost like the guard pin is rubbing on the main plate but it may be a optical illusion?
The problem was the bent pallet fork lever. I straightened it out and the balance wheel now turns freely in both directions. To straighten the lever, I used two sets of tweezers to gently bend it back. It surprised me how soft the metal was and how little force it took.
Thanks to everyone who commented and offered advice on the issue.
    • Maybe I'm over simplifying this and I'm a little late to the discussion, but just by my looking at oil when I use it on a treated cap jewel  the oil stays in one nice bubble, but when I don't it spreads out to the edges of the jewel. I'm not sure (but could well be wrong) but the analogy of a waxed car and rain is accurate in this case, the wax is very hydrophobic and repels the water, however, the process epilame works by is a different physical process based upon cohesion/adhesion (oleophilic) not repulsion (oleophobic)  at least as far as I have read/observed. If one were to use a oleophobic substance equivalent to wax (hydrophobic) then one would need to create a donut shape to fence in the oil, however if one used such a strategy with a epilame which is oleophilic then the oil would sit on the ring of the donut and not in the 'donut hole', exactly where you don't want it. Even is the oil is smeared then the oleophilic epilame should pull it back to the center (see diagram below). Reference
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
