Hi I'm New To Wrt
mlfloyd1
Hi everyone.  I too, am a watch enthusiast.
As you can see I'm starting to build up a tool inventory.  I now see how things start to build up.
I'm glad I found a hobby that I enjoy.  I find it both relaxing and rewarding as I become more familiar with disassembling and rebuilding a watch.  Already I replaced a mainspring and a case crown tube.
The fear is beginning to subside.
Well anyway, I'm glad to be on board and look very much forward to fellowshipping with everyone here.
Here's my temporary work area (my computer desk); I'm working on getting a table top watch repair desk.
Copy that.  I really have to get a separate desk with drawers and especially side-rails.
I've already had to order a click spring that went AWOL after I tried to insert it.  The dark brown woodgrain surface doesn't help either when trying to find parts that pop out of the movement.
Edited by mlfloyd1
Welcome to the forum from Scotland, you're obviously well on your way with this great profession/hobby. I'm sure you'll enjoy being a member of this forum. The boss, Mark, has done a great job setting this place up and his instructional videos are second to none!
Edited by Geo
Welcome to the forum. I am new myself and I see you are very organized... someone gave the suggestion to get a mat and that is one I didn't think I needed until things starting falling and bouncing off my computer desk. I work and go to school so I usually do my watch work late at night. You don't want to be that person  searching all over the floor at midnight for that dial screw believe me!
JC
I find Geo's solution to watch work space is both practical and elegant: http://www.watchrepairtalk.com/topic/841-workbench-height-solution/
maybe you guys might want to try something similar. The advantage is you don't loose desk space due to the portability of it and the height is always right. The raised edges in combination with the mat's texture and color will prevent most parts to get lost. Also a good work place illumination is paramount.
Edited by bobm12
Hi,
   Welcome. I also use a small desk similar to Geo's with the exception that I had mine built with several drawers which I find are completely full of tools. Maybe this weekend I'll post a picture of it. A guy at work built it and on his own installed a felt mat. It's too dark but that's fixed by placing a lighter colored one on top. Anyway welcome to the forum.
Charles K
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
