Loose cannon pinion shaft
p2n
This the Emes I've been working on. I noticed that although it was losing time consistently, it was also losing 'chunks' sporadically.  So checked the cannon pinion and it seemed tight to get off but loose to turn. very loose. Seems like the shaft for the centre wheel isn't attached to the centre wheel.
What's going on here? This doesn't look like it's broken - it looks to be made this way. Assuming that's the case, how do I tighten this arrangement?
P3230001.thumb.JPG.52b128388c86a9d71eecdd4bc28223a3.JPGP3230002.thumb.JPG.1eaea49cab9a850b9318f5195c809e13.JPGP3230003.thumb.JPG.e390edbbbcfd9082dc24c6cb3405665d.JPG
As is visually observant this is not your normal cannon pinion. The cannon pinion has to fit in very very tight to the center pin. The center pin is where the friction is and it is supposed to have a slight bend where it goes through the tube.
I would not bend the center pin!!
So what is the solution to the problem? If bending the center pin is not.
I would flatten a small area. Carefully, until the fit is tight. Could also use crystal glue which is completely recoverable if if works loose again.
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
