Help please. Discovered a small scratch approx. 4.5mm long at the 12:00 position on the crystal that I could feel with a finger nail. I tried to remove it with a dremel and felt polishing tip with a dab of polishing compound but only made it worse. So I am now in search of a replacement crystal. Your help with a link is appreciated. Movement is 5110. Watch is WVA-M650D- 1A2JF. I would consider sapphire if it's not unreasonably priced.
Looks like it's a flat crystal, so you can use a generic. I suggest that you bring it to a good watch shop (where they change batteries and do minor repairs) for replacement. They will measure it and if they can't, you can order one yourself for about $1. Sapphire can be around 10 - 15.
Crystal measures 34mm installed. Ordered a watch press set from ebay. Youtube videos show careful removal and replacement looks straight forward. I'd like to do this myself. But need to know where to order the crystal once I remove and measure it.
Cousins UK, for example. Has most of the sizes for glass and sapphire. Someone has posted that Ebay has even more choices in thickness for sapphire.
Cousins UK ships worldwide at very reasonable prices. I have no ranking for US Ebay sellers, you can look at their feedback.
Thanks I will register with them and order one of their generic flat sapphires after I remove this old one. Not sure of the size yet but I see I can get a 34.1 x 1.0mm sapphire crystal for approx. $27 US plus shipping. Sounds like the plan.
Meanwhile, I have been rubbing the damaged area of the crystal with a q-tip and a dab of .5 micron diamond paste. It doesn't look nearly as bad now.
Ordered a 34 x 1 mm flat sapphire from Esslinger. They are fairly close to me right across Lake Michigan. Should have it within the week. Will post again after install.
sent via htc one m9
sent via htc one m9
They already shipped! That was quick within an hour of placing the order. Regardless the damaged crystal is rather inconspicuous now. And you have to hold it at a certain angle to really see it. But I know it's there. So I'll change it.
sent via htc one m9
The sapphire crystal arrived and I must say I'm am not all that impressed with it. It just a flat piece of blah glass. The original mineral glass has a very slight curve to it. So I decided to try rubbing a bit more with that diamond paste. Went by hand using q-tip, paper towel and a few dabs of the heavier 28 micron stuff. It took several hours of hard rubbing but now all the scratches are gone and that depression in the center is just barely felt. Followed up with some finer grades and used .5 micron as a final polish. I'm happy with this and am thinking about not changing the crystal after all.
5dab3b3d2cd723e5dc64c61017ea560d.jpg&key=703740ef61cb805f6fb366858a8424ff4e66b7cd8235a7ed284e2ea14a385ad9
sent via htc one m9
Which is why using a rotary tool on a felt wheel is advisable.
Not if your in-experienced doing so. The reason it took several hours of hard rubbing was not for the original scratch (easily removed several days ago) but for removing the dimples and marks caused by improper use of the rotary tool and felt wheel. I tried the dremel method twice as shown in the esslinger and other videos and both times I apparently applied too much pressure with not enough movement and the friction overheated the wheel on the crystal causing a dimple and tiny score marks. Suggest recommending novices practice the technique on something other than a good watch first.
sent via htc one m9
I think you were spinning the dremel too fast. In fact, these starting at 3,000 rpm are already too fast for polishing, not too mention buffing. A regular drill actually works better.
Quote
It's always good to learn on a throw away watch. Just like paying attention to what one is doing, and not blame others for own's failures.
  • jdm locked this topic
  • jdm unlocked this topic
Agreed. I have an old '70's Timex that's pretty scratched up. I'll see what I can do. But I believe it's an acrylic crystal so I wonder if a rotary tool would be appropriate?
sent via htc one m9
sent via htc one m9
It's very easy to over do and overheat acrylic with a rotary tool. If I'm going to bother polishing plastic, I do it by hand. Mostly I just replace acrylic, I have a good inventory of round crystals and huge piles of various specialized plastic crystals for vintage watches. Then it becomes a matter of digging through the mountain for the right one :-)
Ah.. makes me wonder if the crystal I've been working on above is actually acrylic. Kinda feels like plastic.
I may contact you if the old Timex needs a new one.
sent via htc one m9
No it's not, as mentioned crystal would overheat immediately and be ruined. Isn't even necessary to use diamond paste with these, any fine abrasive compound will work.
Yeah, I love this watch and won't give it up for nothin'. Perfect size, full featured, light weight, solar powered, syncs every night at 12:04, easy to read digital stop watch, secondary time set to Greenwich UTC, 5 alarms, has a light but the lume is bright and easily visible all night long clear to my alarm time of 5:45. WVA-M650D-1A2JF
sent via htc one m9
At this angle you can clearly see the dimple that is still in the crystal. But it's usually not very noticeable. And not seen in the last two pics above. So I won't change it just yet. Dimple was caused by improper use of a dremel and polishing wheel.
Edited by Dweib
I want to know why the devil this $200 watch scratched so easily. I've been wearing a cheap $40 K&S autowind at my machinist job for several months and not get a scratch on it but the moment I wear this Casio for just one day the crystal scratches up?
My bet is that is is not mineral glass, but some sort of hard acrylic. A dremel won't dimple mineral glass that quick. I've polished several old mineral glass crystals (pocket watch size) with a dremel and never made a mark like that, and if it scratches that easily, it also makes me lean towards some sort of acrylic.
I agree with you. That is my opinion as well. Although the specs claim mineral glass.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
