Hello from Poland
bony
Hello Everyone,
My name is Michael and Im from Poland.
Im In love with mechanical watches since I opened First german Dugena and saw pink jewels in it. It was 2004, I was 14.
I hope I will learn a lot of new things here ;)
Greetings to You all
Hi Michael, Welcome to this fine forum. Yes, get into watch repair. Lots of 1st. class info here some very experienced people at your service. I am just an amateur by comparison. Please carry on. Regards, Mike. PS, I am in the Southern UK.
Edited by ecodec
Message added.
