I need to service a Westminster clock for one of my School projects.
I've only just finished stripping it down and cleaned it so I can now see what needs doing, and thought people here would enjoy some 'before photos' and hopefully in the not too distant fusture I will be able to provide some 'after' photos.
Fairly standard looking clock, it is a Hemle, but just stamped 'Foreign' on it.
I'm pretty confident of the manufacture date.
Now remember if it doesn't run, just add more oil.....
Hermle4.jpg.ab4a67771bc73b121365596b3ed45fb6.jpgHermle4.jpg.ab4a67771bc73b121365596b3ed45fb6.jpg
When I got the barrels open the mainsprings were completely dry, but there was oil on everything else. I'm wondering if the movement got the 'Dunk the complete movement in petrol, dry off and just oil what you can get to treatment' at some point in the past.
Pretty much all of the pivots need polishing, one pivot hole has punching up on it, although atleast half of the pivot holes will need bushing as does atleast one mainspring barrel and the anchor needs the pallets refacing. Lots of work but hopefully all achievable although the pallet refacing with offcuts of mainspring is something I've never done before.
Nice old clock and a good project, gotta love the old dunkers, there is a video on YouTube and the guy is so proud of his work showing you how to do it..At least he does it outside, a tray full of petrol or gasoline as he calls it would make a nasty mess of your house if it caught fire..Always know when the have been dunked with the dry barrels..Are you doing anything with the case? Good you are going to use old mainsprings, I have made some great hands for School clocks that I have made from scratch..
Good luck with this project, it will be good to see the final finished clock..
Len
Bog standard chime. You need a mainspring winder for those springs. Any chance of a look at the pallets, it isn’t very often the pallets of these clocks need to be re-faced.
Pallets are heavily warn.
I have had it confirmed by both my lectuers they need refacing. Im at work so dont have the photos handy.
Either way its better I learn to do this on a clock I own than a customers
I'm starting to be drawn towards these giant unwearable watches that you refer to as 'clocks' - there is something rather awesome about the scale of them and the different techniques involved.
Clocks are larger in size so in theory easier to work on. However clocks require unique tools such as a  good spring winder, a stand to hold the movement whilst testing and regulating. Re - bushing is also a common task required with the vintage clocks which does take a bit of practice to achieve success. Also getting a Westminster clock to work & chime correctly can sometimes be a real challenge. So you are correct clocks require different technics for sure but as with watches the work can be very rewarding.
Years ago I switched to restoring and repairing clocks (there is a difference) In the past I have restored some wonderful time keepers. Making the parts was a challenge but such fun. Working on complicated mechanisms many with month duration. There is always something new, you never learn everything.
I'm a member at EFHC and am currently doing watchmaking but have been sneaking into the clock workshop and looking at the big tools. It won't be long before I'm in there officially I'm sure.
Good for you. I found clock movements far more interesting then watch movements. Much more goes wrong and far more to fix.
The clock is now ticking and chiming, just need to finish regulating it.
I won't go through everything I did, but just show what I think are the more interesting things.
Firstly the Chiming barrel arbor hole had worn oval and need bushing.
First the barrel was set up on my large lathe and centered using a dial test indicatorcentering.jpg.110286f5eade3520d3fd401a99cb3d2f.jpg
It was then drilled out to 10mm and the hole was measured to ensure it was exact
A brass clock bush tube was selected that was 11.4mm outside diameter and 8mm inside diameter.
The thickness of the base of the barrel was measured and the height of the lip of the bush was machined 0.2mm taller than the thickness of the base of the barrel and the diameter was machined down to 10.05 to be a friction fit inside the barrel. A 1mm lip was left to sit on the outside of the barrel as this would not impact end shake and gave added strength.
The bush was then transferred to the watchmakers lathe to clean up and add a leading edge chamfer to make it easier to fit. Finally it was pressed into the barrel using an arbour press.
Once the mainspring arbor had been polished the bush was then broached to size using clockmakers broaches.
I needed to polish a number of pivots that were all 0.8mm in diameter. I know some people can just hold the wheel in a pin vice and using a pivot file and a block of wood polish the pivot, but I'm not that good.
I got some bar stock that fitted the tailstock on my watchmakers lathe and drilled it 0.8mm. I then turned a taper to the end and transferred it to my mill and milled just over half way through the bar so just slightly less than half of the 0.8mm hole was left.
I then set up my watchmakers lathe as a turns and using a pulley that I had made previously which has 3 screws 120 degrees apart screwed it onto the arbor and using a bamboo rod and finishing line made my bow so I could use my lathe as an oversized jacot tool.
The pivot was filed with a pivot file, finished with a triangle Arkansas stone and burnished with a pivot bunisher.
Hope this is of interest to some people.
    • That's just it. I am actually looking to see if I can replace the second wheel on a Omega 3220 which uses the ETA 2892-A2 as it's base. The 3220 actually has a push fit chronograph driving wheel on the pivot rather than a second hand. Not certain that this would be a direct replacement but it could be worth a shot versus paying $150AUD for the Omega part.
    • Yes, being lathe deprived is a problem that I have, so obviously interested in solutions that don't require one.  The Balance Staff removers are interesting. I wasn't sure if you could get them in a size to suit a typical wristwatch movement, I thought they were more suited for pocket watch balances.  I was surprised to see a staff just pushed out with a Horia tool but I guess if you get a very close fitting stump it would potentially do the same amount of damage as a remover (the only difference being that the remover seems to clamp down the cross arms of the balance immediately surrounding the staff). I did read somewhere that Rolex (who apparently recommend this) balance wheels are harder than others. This is maybe one to try on already scrap balance.
    • Can you confirm the movement number you're working on.
    • Just checking terminology here. When a pivot is described as having a certain height is that measured from pivot tip to pivot tip or from the face of the wheel to the tip of the extended pivot? I have a bit of a strange one that measures closer from tip to tip but not from the wheel face to tip (I get 3.1mm from face to tip and about 3.6mm tip to tip when badly measured with my Vernier calipers)
    • This is the best option - if you have a lathe.  For those of us without, I use a Balance Staff Remover as shown in your pic. Using this, I have not seen any damage to a balance.  Rolex recommend just pushing it out as their balance arms are quite hard. But, as @Klassiker suggests, do a search of the forum and you will find plenty of discussion.
