Demagnetisation
BUSAKAZ
Hi all
Fore years now I have been putting watch parts in a plastic bag after cleaning when demagnetising, just wondering weather i would get the same results if I left them in the little baskets what do you think.
cheers kaz
 ps it’s a Elma antimag demagnetiser
I would think you would, as long as the basket is of a non-magnetic material (which I suspect most are). My basket is a soft metal, probably a mix of aluminum and or tin, but definitely non-ferrous.
I put my small parts in a small plastic container with a lid, about the size of a bottle cap, and it works fine.
I always demagnetised the complete movement before taking it apart. Make sure your tweezers, screwdrivers oilers and the cleaning machine basket are as well. If you do this and get into the habit, it will save you a lot of time.
Forget the screwdrivers if you have anti magnetic ones.
So doing them in the baskets would have the same results then, I guess there is only way to find out is to try it.
Ok a little update on this, last night at the Milton Keynes BHI meeting I asked the same question, once the movement has been cleaned and assembled you put the movement on the demagnetiser dial down press the button,turn it over dial up press the button then turn it 90 deg then press the button again that’s it, if you keep trying to do this it can re magnetise the movement, this is for the ELMA ANTIMAG only there was 6 people in the conversation and they all agreed.
Cheers Kaz
13 minutes ago, BUSAKAZ said:
You don’t,they have gone to the watch gods.
One of the many sacrifices they demand of watch repairers. Can you imagine all the steampunk art they have created over the years? :D
Edited by khunter
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
    • There must be a ring around the movement that is not a part of the case and the movement will get out together with the ring.
