Regulator doesn't regulate.
Scouseget
Hi, you'll be happy to hear it's warmed up considerably in Edmonton, it's now all of minus 13 degrees - where's my margarita?
I've just overhauled a 1908 Waltham, size 16S, open face pocket watch. It want reasonably well, though I had to cannibalize another old Waltham for replacement parts. I also fitted a new the balance staff.
Anyway, I do have a problem, which is regulating it accurately. I got the timing almost right, at least in the dial up position, by judicious use of timing screws. Final adjustment was going to be by the regulator, so t that end, I ensured the hairspring was located between the pins. What I then found was that this made no difference to the timing, well perhaps a fraction of a second. The hairspring is an overcoil type and the regulator pins act on the inner radius of the hairspring, i.e., the radius that the stud connects to the bridge at. The hairspring doesn't then gradually extend out to the outer coils but rather abruptly doglegs over at a pretty severe angle; I hope I've explained this ok.
I'm sure I could get this running as accurately as a watch of this age is capable of, including in positions using the timing screws, however I would still like to have a regulator that actually regulates. Any suggestions you may have will be appreciated.
In a similar vein, I've noticed that very few old watches seem to behave themselves on the timing machine, I mean the traces are "noisy", as in all over the place, and frequently the timing machine will not establish the beat rate automatically, and won't lock in even when set manually at the traditional 18,000 BPH as it keeps resetting itself. This never occurs with newer watches so I'm wondering if it's just unrealistic to ever expect really old watches to run well enough for a timing machine to be of use. I usually simply time them using a stop watch over time and can usually get them to run reasonably accurately. Any thoughts on this issue?
Hi, I’ve recently gone through a similar era Waltham 16s. I would look for hairspring rubbing either the bridge or the wheel. There may be a stray hair somewhere as well. I’m sure you’re aware of all of these possibilities but it dormant hurt to recheck under higher magnification.
It can be difficult for a watch as old as the one you're working on to give good readings on a timing machine. Sometimes it is better to simply let it run overnight and keep making minor adjustments against a stop watch until its within a decent range. @GeorgeC is correct about checking for rubbing and fouling on the hairspring. You don't mention how much error, but if its 3-4 minutes per day, I'd say that's  OK.
J
J
Most of the work I do is on these old pocket watches, and I can say that getting a clean reading on a time machine IS possible, there are just a lot of things to look for. Rubbing of the hairspring is one, but the alignment of the spring within the regulator pins is a big one. The pins should not pinch the spring, it should sit between them with the tiniest of space on either side, throughout the movement of the regulator. Make sure the pins are perpendicular to the bridge, not angled in or out. Moving the regulator to its extremes should not significantly disturb the shape of the hairspring. It takes very small adjustments to get it all right, but I've done it, andI'm no where near a pro. Mark has a good video on adjusting hairsprings, I'd have a look.
Also getting the dial up/down positions aligned timing wise is the first step, and most of that is done with making sure the end shake is proper, and there are no parts binding in one position or the other. Sometimes with too much end shake the pallet fork will contact the roller table and cause crazy noise and erratic beat readings on the timer. It just takes time and patience but it can be tracked down. Here's a great website that covers the subject very well and thoroughly.
adjustingvintagewatches.com
You had to cannibalize another watch for parts which parts did you take?
You said the hairspring is between the regulator pins how much spacing is between the pins?
Then maybe a different thought and approaches needed here. Simplistically you can't regulate until the watch is running well and has a reasonably decent image on the timing machine. So timing problem is one problem watch not running properly whole variety of reasons is another problem. Just because the balance wheel is moving doesn't mean you can regulate the watch and everything will be fine.
There isn't any reason why in ancient pocket watch can't keep time on a timing machine. It just requires a lot of effort at times to make that happen. Other times there very happy on the timing machine. But usually effort is required to get that remember they been out there for 100 years of people playing with them adjusting things moving things. Then there's just the basics like did you change the mainspring? A lot of people are scared of the mainspring and usually on pocket watches their set.
You may have already performed this but, make sure to unscrew all balance cap jewel screws so you can separate and thoroughly clean those components and re-oil.   Look for any pits in the cap jewel or a broken hole jewel.  Are the pivot points of the staff in operable condition?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
