FHF 90-5
Nunk
Hello
I have been learning how to repair watches for the past 3 months now.
its seem to be going ok I think.  Body count is starting to drop now.  When I first started all I had to do was touch a watch and it would stop working :):).  Thankfully I am starting see some progress now.   So I got a bit brave and decided to service a FHF 90-5 dated auto.  Couple of things went wrong.   The date changes at 9 oclock :o and the case spacer wont go back in ????  I am sure it goes in after the movement.   It just wont fit and the rotor brushes against it.   What is going on with this ?????
For the date changing at 9 oclock, it may have to do with when you put hands back.
Before putting the hands back on, did you set the date properly (turn the crown until the date just changes, no more)? That's midnight. Install the hands back on in the midnight position. You should be all set
looking at it again I dont think its a spacer problem, its something else.    Jeez putting the movement back in was meant to be the easy bit.  I am going to have take the auto mech off again grrrr
I just serviced a pair of these movements around 2-3 weeks ago.
You're supposed to install the spacer onto the movement before the whole movement goes into the case. (simple press fit)
The date changing wrong is due to the fact that you installed the hands incorrectly.
As has been said, with the hands uninstalled, turn the crown around (in time setting mode) until the date changes. That means that you've reached 12:00PM, the moment when the date should change. Now you simply have to install the hour and minute hands (showing 12 o'clock obviously). The seconds hand doesn't matter where it'll point.
Edited by Chopin
Ok thanks.
I think I need to strip down the Auto mech again.  it does not seem to be engaging (((sigh))).
Did you not install a gear correctly ? Is the problem with the rotor itself or below it ?
When you install the rotor you have to press it down onto the movement and rotate it slightly at the same time so that the wheels will start to engage.
Yeah I stripped down the auto mech again and spotted a gear round the wrong way.   Seems to be ok now.  I was going to start work on my Traser with a 2824 movement after this episode but I think i need a bit more practice.  Thanks guys
    • Hello and welcome from Leeds,England.  Ask away.
    • What cutter are you using can you video the action
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
