Wyler Vetta High dome crystal
Welcome to the forum. Photos of the watch and particularly the movement will be need.
The 3ADJ isn't the calibre it's just how the watch was calibrated i.e. in 3 positions. A photo of the crown would answer if it's snapped or not.
Hi Tigermuffins, Replacement parts for Armani watches are, in my experience, rather difficult to find. This is because not a lot is known of the movements and parts that have been used and there is very little information available. I repaired one myself for practice and spent a LOT of time finding a replacement wheel. That particular watch used a Chinese movement, that I could only identify after doing a lot of research. I think your best bet would be to find a second hand watch of the same model, or one of the models that were released around the same time, and use the stem + crown form that one. I found attached article of its release and probably one of the other tank models would also work. Maybe one of the other members has more info on the movement used for this model, then you could try to find a replacement stem and a (generic) crown. Good luck on your first project!
By Embezelled · Posted
The Citizen movement is 3ADJ. One reason I have some hope that the crown/stem didn't snap is that the end looks clean rather than broken. I've got 2.3 mm of threaded "stem" coming from the cap. Let me see if I can take a picture with sufficient detail to show it.
