A really useful source of information is Christian aka watchguy.co.uk
Check out https://watchguy.co.uk/cgi-bin/library?action=show_brand&brand=Roamer and you'll see he's worked on three 522's and taken photos along the way.
I've worked on a Limelight and Searock with 522's in the recent past so may be able to help in the unlikely event you hit an issue.
thanks for that.should help.if not i will get back to you Watchmaker.Bernie.
  • 11 months later...
i need a spring for the date selector?.do you know where i can source one?see pics. i think the part no is 3480 (440)?
Hi Bernie
I think the part you need is actually # 2575 i.e. the date jumper spring. Part # 440 (3483) is the yoke spring used in the keyless works. I expect you have the parts document for the 522 already but if not you can download one from here: https://www.cousinsuk.com/PDF/categories/2348_MST 520 512 522 523.pdf
If you concur that it's part # 2575 you need then Cousins do one at £5.95 if you search for item number MST5212575.
As a P.S. ...
It's a frustrating truth about watch repairing that there are small 'commonish' parts that must cost pennies to produce but pounds to replace. Your spring is a good example as, with postage and VAT, it will cost over a tenner to replace! But it's just a super-simple U-shaped spring! Grr!
There seems to be a real market out there for a supplier to produce a set of small date jumper, click springs etc. I'd buy them! Cousins do do a set of generic Shepherds Hook Springs (item W36105) but they're all pretty large. It might still be worth adding these to your order as there may be a handful in the selection that could come in useful in the future...
3 hours ago, WatchMaker said:
As a P.S. ...
thanks watchmaker.i realised while searching later yesterday that it was indeed the date jumper spring and it is no.2575.i already have shepherd hook springs so i will have a look at what i may need so i can justify the postage! like you i cannot understand why some bright spark has not thought of manufacturing these "common" items.they would make a fortune.again thanks for your help and merry xmas.B.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ?
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
