The Cousins web site document download section has the data sheets for this movement to download.
Just now, WatchMaker said:
A really useful source of information is Christian aka watchguy.co.uk
Check out https://watchguy.co.uk/cgi-bin/library?action=show_brand&brand=Roamer and you'll see he's worked on three 522's and taken photos along the way.
I've worked on a Limelight and Searock with 522's in the recent past so may be able to help in the unlikely event you hit an issue.
thanks for that.should help.if not i will get back to you Watchmaker.Bernie.
  • 11 months later...
i need a spring for the date selector?.do you know where i can source one?see pics. i think the part no is 3480 (440)?
Hi Bernie
I think the part you need is actually # 2575 i.e. the date jumper spring. Part # 440 (3483) is the yoke spring used in the keyless works. I expect you have the parts document for the 522 already but if not you can download one from here: https://www.cousinsuk.com/PDF/categories/2348_MST 520 512 522 523.pdf
If you concur that it's part # 2575 you need then Cousins do one at £5.95 if you search for item number MST5212575.
As a P.S. ...
It's a frustrating truth about watch repairing that there are small 'commonish' parts that must cost pennies to produce but pounds to replace. Your spring is a good example as, with postage and VAT, it will cost over a tenner to replace! But it's just a super-simple U-shaped spring! Grr!
There seems to be a real market out there for a supplier to produce a set of small date jumper, click springs etc. I'd buy them! Cousins do do a set of generic Shepherds Hook Springs (item W36105) but they're all pretty large. It might still be worth adding these to your order as there may be a handful in the selection that could come in useful in the future...
3 hours ago, WatchMaker said:
As a P.S. ...
thanks watchmaker.i realised while searching later yesterday that it was indeed the date jumper spring and it is no.2575.i already have shepherd hook springs so i will have a look at what i may need so i can justify the postage! like you i cannot understand why some bright spark has not thought of manufacturing these "common" items.they would make a fortune.again thanks for your help and merry xmas.B.
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
