Hi everyone. I came across this staking set. I don't think I need one yet. But I am not sure when I will come across another one. Is this a good brand? Brand is "Dracip". Looks to be missing a bit? Seller is asking $55 locally. Please advise, thanks.
OMG... This is my first staking set. Well, not the actual one, but the same make and everything!
It cost me £40 or £50, I believe. It did what it said on the tin, so to speak and I used it for staking back hairsprings to balance staffs and closing up holes.
The only problem with Dracip staking sets is the stakes aren't the same width as most others. They are larger at 4.75 mm instead of the usual 4.7 mm. I found a load of stakes that size, so my Dracip set is well stocked and you can use any anvil from any other set. If you get an 8 mm lathe, you could turn your own anvils and even stakes.
As a starter staking set, it served me really well until I got the staking set bug and now I've got seven, or maybe eight.
As I said, it'll do some basic stuff, which is great. Worth the small amount of money in my opinion and when you want to up your game, buy a better set and sell this one.
I've still got mine, as it is my first staking set and I've got quite attached to it, so would never let it go.
Amazing stuff! From what I can see, it looks like the front has 3 out of 4 stakes. Could it be missing a critical stake? I’ll try to inspect it further, but it’s a bit far of a drive for me. Luckily, my friend lives just 15 minutes away from the seller!
1 hour ago, Pap3r said:
How much would something like this be worth?
I am interested in the stakes set here.
Go to ebay and watch over time. Staking sets go from $150 to $500 depending on brand, configuration, and condition. I have maybe eight staking sets and never paid these prices. All bought locally at nawcc chapter meetings, or word of mouth, and generally bought as part of a lot. AND I have always gotten some broken stakes
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
