I am using tg-timer to time an Unitas 6340. The ebay seller said it was serviced. Apart from the slow rate, it actually looks pretty good. However, I noticed some subtle problems with the waveform of the graph. First, on the bottom panel, there is an extra noise detected. According to this, something is glazing in the balance. Second, in the middle panel, right before the pallet locks the wheel, there is an extra noise. Does that mean the balance is hitting something it's not suppose to?
I am new to watch repairing so I am wondering if I am reading this graph right.
Here's another timegraph of a watch. It's a vintage Russian watch that I bought from ebay. It looks like it obliviously needs a rebuilt from the irregular chart. It doesn't say it's been serviced and you can see the results.
May be the case but there’s not tons of info on sound wave analysis. I’ll leave it to more experienced guys to comment.
I’d stick to the standard rate, BE and amplitude on a few positions.
I would go chasing the sound waveform if all else looks fine.
Of course, just MHO.
Cheers!
There are a number of things that can cause this You need to carefully observe the balance wheel under a loupe is it untrue? and catching somewhere? pallet fork bridge maybe, is the hairspring out of shape and catching the center wheel ?
careful observation of the balance may make the cause obvious.
Timegrapher's can show you symptoms  but quite often you have to do the diagnosis.
It should also run better than -90 seconds a day
Cheers!
Sorry, meant “I wouldn’t go chasing...”
I rather liked something that my instructor said when I was in school don't please the timing machine. Timing machine points you in directions gives you clues but perhaps think of it more as reading a crystal ball it's not always an exact science. Then when you toss in the Oscilloscope part and start trying to make interpretations from that things get much more complicated. If you get obsessed about having perfect waveforms which are going to be absolutely impossible to have you going to be chasing your tail forever.
Then you have a rather impressive amplitude which is a little excessive?
Then realistically to do proper analysis of a watch it needs to be done in multiple positions. Problems don't always show up when the watch is in only one position. So what tends to work well is six position timing. So this is dial-up and dial down and Use of the crown is used as a reference which would be crown up down left and right.
Hi,
I will comment the picture in the first post:
- the extra noise in the bottom is most probably a ringing hairspring. It comes from sti:cky regulator pins and does no harm (often you can hear this ringing).
- there is no extra noise in the middle, waveform is absolutely normal. The tick noise can contain three, four or more single pulses. If you wonder where they come from, study books dealing with escapements.
What else you can see in the same picture: your TM does not recognize the first pulse of the noise! A common issue of certain TMs,  A Weishi user has no chance to recognize this faulty measurement, your scope picture  fortunately shows it. Hence the too high amplitude value, what JohnR already mentioned.
Frank
A recent Mark's video documents that: A fault not revealed by a standard time-grapher.
    • I'm struggling to find information on adjusting a Seiko bracelet. I can pull the locking pins out but the links remain very much together. I don't want to bend anything without being sure I've tried everything. Anyone else adjusted one of these?
    • Thought I’d say hi. I’m from outside of Glasgow and have a small collection of watches, which I love. My love of all things watch comes from my Gran having been a Jeweller, and also from being the custodian of a 1979 Omega and also a few vintage Timex mechanical watches. I have some more modern watches as well and i love them all. I’ve recently started looking into watch repair and assembly as I’d love to know more to see if I could work on / service some of the watches myself. To that end I recently assembled an inexpensive automatic GMT using odd parts, a Seiko movement, and by referring to many YouTube videos. Hand setting caused me no end of pain and once I receive a new second hand I’ll try again. Difficult but very therapeutic - many thanks in advance as I’m sure to ask so many “stupid” questions. Best Regards
    • Few years ago I needed to fix a Cornavin my granny gave me (believe the mainspring broke). I couldn't find a watchmaker. There's a keycutting chain in the UK called Timpsons who said they could post it off somewhere and it'd be £250. I wondered around town for a bit and realised that watches are made by people (duh), I'm people, so I can probably give it a go. I did a bit of research, bought a little tool kit, and proceeded to break bits (shock absorbers, naturally). I then put all the parts in a bag for safe keeping.  Since then I've developed a healthy fascination with the subject (not an obsession, just a healthy - think about it everyday now - kind of fascination), and amassed a good bit of literature and some cheapy tools. I still haven't fixed the Cornavin (it's a 2614.2H movement, same as a Poljot and I have enough spare parts now) but it'll be the one after my next project. Currently assembling a Raketa 2603 for the practise. I took out the little shock absorbers, struggled to put them back in, walked away for a cuppa and searched the internet for any tips. Then I found this forum, been here before actually, figured I'd join. I feel like I've developed a smidge more book knowledge than practical skill, so that's a point I need to work on. I'm having doubts the Raketa will work once I'm done, but it was cheap enough not to matter and worth the practise. So here we are. Hello
    • I was thinking it might be nice to see a picture up above or the picture I'm going to paste down below from up above with the escape wheel just setting their. Then it almost looks like the lower jewel is out quite a ways? But maybe it's an optical illusion with the shellac yes the assortment set over time have become something other than what they once were. Like it work with a assortment of Waltham jewels for burnishing in and the last time I tried to find one I discovered there all randomly assorted. Then of course often times the assortments had a tiny quantity of things and the entire container got re-tasked for other things and down the road somebody sells it totally clueless of what they're selling. But in the case of roller jewel's especially after the longer ones of pocket watch size for a single roller then randomly and bottles is definitely good. If you really careful you may be able to place the roller jewel on a flat surface and use calipers although a bench micrometer really is preferred.
    • Have you search for a new winding crown using Tissot case id? You can also find a replacement crown by size / type of the crown you currently have: https://www.cousinsuk.com/category/tissot-crowns-by-size They are dirt cheap.
