Jump watch sticking
Boogi11
Hi. I have stripped and rebuilt a jump watch and it appears to work fine however it is getting stuck in the hour movement. The minute hand is a nice tight fit with no slippage and the full movement works fine when adjusted on the crown. However under its own steam it sticks . It’s happening as it jumps from one hour to the other . Any ideas . Should anything on this top side be oiled d86677af7b1853ad2146098cf8cc966a.jpgff0585ee23c68628415a7cdefb89172b.jpg
What is the movement? Does the hour not turn over, but it keeps ticking? If so then problem is mainspring barrel cover/clutch wheel combo....the hour wheel is driven by a gear on the mainspring barrel, which is connected with a slipping coupling--Needs more tension. I'll tell you how to do it, once you confirm.
J
Ah OK its a BFG 582. The problem isn't with the barrel, because this doesn't have a slipping clutch there...its this part:
This  part connects directly with the barrel (you can see the gear just below the part being pointed to). This cannon pinion combination gear should have enough tension that it turns the hour wheel, but enough "give" that it spins when the setting lever is engaged the time. You'll have to remove the dial to check it.
J
The springs’ “beaks” should be oiled like on any calendar works. D5 should be fine for this. There may also be other moving parts like those found in calendar works which should be oiled with a thick oil.
Assuming it worked ok previously, the spring tension probably does not need to be adjusted.
Check all of the contact points under the dial.I f the spring is not properly positioned the mainspring will not have enough power to overcome the tension...but that should cause the watch to stop ticking. If the problem is where I think it  is...This movement might be a little different with some parts, but check these areas:
DSCN5424.thumb.JPG.50672e3b7f3c0a669c2509c361193952.JPGDSCN5425.thumb.JPG.4d1b5ce9ae2dddb4f499bc84452771c1.JPG
J
Edited by noirrac1j
J
Reply. Cheers. Will do. I may have the hammer spring in the wrong way around . I may try this first
    • If you tend to be a little heavy handed then heres something that might help you to prevent cap jewel loses if you have some spare tweezers. File a round into each of the tips so you can grip a capstone or chaton while oiling or moving them around. Instead of filing along the length, angle file the tips first then file the rounds perpendicular to the angle. This way the tweezers wont get in the way of the oiler. Choose an angle that suits your natural hand grip position. The tweezers can now grip round parts on four sides Instead of two that often flip that part away.
    • I had noticed that video before.  He has a separate video for the reassembly. When he started the reassembly with using peg wood to oil a jewel I have to admit that I didn't watch much further. He also advocated not lubricating the center wheel arbor because the cannon pinion is friction fit. There is also a blog post (Adventures in Watchmaking, I think) that has a bit of info but not much at all with the oiling.
    • In view of the modern lubricants available, would you lubricate a clock movement differently today?
    • Yep thats the way it goes. The trick is to lead it into a false sense of security. Go through all the motions of ordering another one but dont actually click that final buy it now button, then stand up say " oh well at least I have another one on the way" .  It will pop its head out and shout " SUCKER ! " . They've done studies you know 60% of the time it works everytime.
    • Hi. I used to live in Tadcaster nor York , there for 40 yrs  moved Aberdeenshire as the place was falling apart.  If you need anything just ask the members on here are very good and patient.
