Jump watch sticking
Boogi11
Hi. I have stripped and rebuilt a jump watch and it appears to work fine however it is getting stuck in the hour movement. The minute hand is a nice tight fit with no slippage and the full movement works fine when adjusted on the crown. However under its own steam it sticks . It’s happening as it jumps from one hour to the other . Any ideas . Should anything on this top side be oiled d86677af7b1853ad2146098cf8cc966a.jpgff0585ee23c68628415a7cdefb89172b.jpg
What is the movement? Does the hour not turn over, but it keeps ticking? If so then problem is mainspring barrel cover/clutch wheel combo....the hour wheel is driven by a gear on the mainspring barrel, which is connected with a slipping coupling--Needs more tension. I'll tell you how to do it, once you confirm.
J
Ah OK its a BFG 582. The problem isn't with the barrel, because this doesn't have a slipping clutch there...its this part:
This  part connects directly with the barrel (you can see the gear just below the part being pointed to). This cannon pinion combination gear should have enough tension that it turns the hour wheel, but enough "give" that it spins when the setting lever is engaged the time. You'll have to remove the dial to check it.
J
The springs’ “beaks” should be oiled like on any calendar works. D5 should be fine for this. There may also be other moving parts like those found in calendar works which should be oiled with a thick oil.
Assuming it worked ok previously, the spring tension probably does not need to be adjusted.
Check all of the contact points under the dial.I f the spring is not properly positioned the mainspring will not have enough power to overcome the tension...but that should cause the watch to stop ticking. If the problem is where I think it  is...This movement might be a little different with some parts, but check these areas:
DSCN5424.thumb.JPG.50672e3b7f3c0a669c2509c361193952.JPGDSCN5425.thumb.JPG.4d1b5ce9ae2dddb4f499bc84452771c1.JPG
J
Edited by noirrac1j
J
Reply. Cheers. Will do. I may have the hammer spring in the wrong way around . I may try this first
    • Welcome to the forum Dan, enjoy.
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
