Dating an Ansonia Slate Clock
Tmuir
I recently picked up this rather sad looking Ansonia slate clock for a quite reasonable price. (The seller counted my offer with an offer $50 lower than I offered to pay)
Other than a missing pendulum it is complete.
I've not looked too closely so haven't decided if someone painted the slate to try and make it look better, or its just filthy, but by the weight of it its definitely slate
Are there any Ansonia experts that could date this or give the model name? I'm guessing 1880 to 1890, but that is just a guess.
The corners and top that look to be hand painted badly gold, would this of been originally painted gold, or gilded?
I do like the enamel dial and can see the potential under the grime, and yes it will need a number of bushes.
I do have the gong too, it had become unglued from the clock, so it is not sitting inside the movement
Edited by Tmuir
The link I provided is what you needed. If you look at it again you will see the label of 1883 up to 1929 Ansonia where produced at Brooklyn, New York. Your movement is stamped Ansonia Clock co New York. One other thing if the glass is thick and original it will be from the early period. Thin glasses were fitted later. You also might find more info under the dial.  The hands are a style called  fleur-de-lis which is a French style which means Flower and are very popular with French clocks.
Clockboy you are correct these American clocks are not in the same class as French movements, there made of soft steel and poor grade brass. The reason these movements had lantern pinions was to take the wear and tear of the extremely powerful springs, the old springs are also made of poor metal. I don’t know if this is true I was told the reason the main plates are skeleton was to save on cost.
I would agree definitely after 1883, although it would be nice to tie it in tighter than that.
I remember reading somewhere that these clocks were made to counter the french slate clocks coming into the US, Ansomia also made cast iron clocks painted to look like slate and cheaper wooden cased clocks painted to look like slate or marble too.
As oldhippy says not as good quality, or worth as much as the French slate clocks, but still interesting none the less
Yes you are right.
  • 4 years later...
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
