Need help with hands
Broam
I just replaced the chronograph hands on an old watch that has a Valjoux 7734 movement in it. The new hands appear to sit a little higher due to the stems being slightly longer. Now the hour hand hits those chronograph hands. I think there is room to make adjustment. It would require bending the minute hand then the hour hand slightly. What is the procedure for doing this? Can it be done with the hands still on the watch? Thanks!!!
You can bend the tips of the hour hand slightly to clear the chrono hand, or you can also take a fine-cut file and reduce the height of the stem a little so that is doesn't interfer. You can bend the hands while still on the watch with brass tweezers. Be careful not to slip and scratch the dial.
J
Id be tempted to remove the sub dial hands, grip them by the arbor ('stem') and rub the arbor on something like an Arkansas stone until they're the desired length. Tweaking the tilt of the hands is also doable, but less ideal, it might make them look slightly 'wrong' if nothing else. That being said I have done it a few times, my preference is for using some pegwood with a wedge-shaped tip and to push up on the hand from underneath, no metal to mark the hands and dial and you're also not touching the top of the hand. (unless you go to far and have to push it back down)
Perhaps obviously: just make sure the hands are at different position so they're not getting in the way of the hand you're trying to bend and go little by little.
Edited by Ishima
Reducing the pivot length wont make any difference in the hand height, since the pivot is conical. Best way is to make the hole on the hand a bit bigger with a broach.
Bending the hand on the pivot is a bad idea. Lifting the tip of the hand exert a great torque at the pivot making it to bend... worst, it can stick in the hole or break.
The rule always applies that dont make any change on the original parts which were doing fine before the service. Make change to he parts which are new!
I agree with broaching the collet. For smaller collets, I use a needle.
Also make sure that the hour and minute hand collets are not just worn/too wide. I usually tighten them when necessary with a jewelling set.
General rule is to aim for a gap of one-hand's-thickness between hands. It's a bit vague, but it's a starting point.
Edited by rodabod
Broaching may be the better procedure, but if you have a hand arbor of generous length and it's sitting too high i maintain you can achieve the same result by shortening that arbor, because quite simply, the hand is lower before you even start to press it on, so of course the friction will max out at a point with the hand being lower than before. The fact that the pivot is a conical point doesn't negate that, not in my experience.
Edited by Ishima
You guys are overcomplicating this. Ive reduced the stem height on hands with a fine cross-hatched file and it DID reduce the overall sitting height. ThEre is no need to broach, and all that can happen is the hand may no longer sit snugly on the pivot. I've also slightly bent the tips of sweep second hands to that they  clear crystal/glass  and also slightly bend them upward IF they happen to hit  each other.... I'm taking small amounts of torque not using a ham-fisted approach...sheesh!
J
Edited by noirrac1j
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
