Unknown Tool from Staking Set
Relentless
Just recently bought a K&D 18 Inverto staking set on eBay, all the stomps are complete and it just missing a few stakes.
The staking set included this weird looking stomp with a tightening lever (it seem like it) try to google for some info but failed to identify it.
Attach is the image of the unknown tool, if I may add I also want to know the purpose of the 10 pins placed alongside the stomps (highlighted in red)
Thanks in advance
What you have is a incomplete combined jewelling and staking set , it is perfectly serviceable as is as a staking set but there are parts missing which will make it useless as a jewelling tool,  the pins are for pushing out friction jewels, the other odd looking part I have no idea but if its Kendrick and Davis it will probably be on the following site somewhere,
http://kanddinverto.weebly.com/
Of the items in the staking is set circled should be the reamers for the jewelling attachment for the staking set that casually appears to be missing? Then the ministry tool is also missing something. It's known as a Balloon Chuck may go by other names and other parts of the universe. It's used to hold a balance wheel in a lathe they can polish the pivots. Which without a picture showing it probably makes no sense at all by my description. But I did find you a picture online at least showing the balance wheel in the tool.  You do have to scroll quite a ways down the page but it's there.
http://www.geocities.ws/dushang2000/Lathe Tools/Lathe Tools.html
Hi Wls1971, ahh so its for pushing friction jewel, so not only the stakes are missing also the jewelling attachment, anyway I have a Seitz jewelling tool so should be ok, is the jewelling attachment sold separately or as sold together with the set?
Hi JohnR725, it looks like the balloon chuck for the lathe you mention. oh well, I guess I have no use for it.
Thank you both
Kendrick and Davis made  two friction jeweling attachments that could be retro fitted to various older frames and to the 18 series of frames the attachments where cataloged as a 540 and 540R, thats what appears to be attached to yours but minus the lever and micrometer adjustment.
  • Similar Content
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
