French Mantle (Slate) Clock Movement
Folkvisor
Smooth snail wheels are machined in such a way that with each hour the rack drops down a tooth at a time, the only difference is its more difficult to see and judge. With many movements the minute, hour and sub wheels are marked by a small punch mark, have these lined up and all should be correct.
The strike wheels with pins need to be in the correct order. Imagine a clock face and you are looking at it.  The wheel next to the fly should have the warning pin at about 9 45 or 9 50. The gathering pallet wheel with its pin should be resting on the stop leaver inside the movement that is the lever just above the hammer lever. The strike wheel (the one with loads of pins in) should be clear and not in any lifting position of the hammer lever. The gathering pallet should be attached onto the extended pivot at about 10 to the hour (you can always move it if need be) You should have two pins set in the back of the minute wheel, which lift the lever (red arrow) this will lift part (green arrow)The rack will drop down onto the snail, these levers at the time of working also release the wheel next to the fly wheel with the single pin against the guard which is attached to the lever  (red arrow) inside the window (blue arrow). This is called the warning, note the hammer at this stage should not be lifting. When the clock is at the hour, lever (red arrow) will clear the pin on the minute wheel, the guard will also drop causing the strike wheels to rotate. Depending where the rack drops onto the snail will depend how many times it strikes. If there is no punch marks on the wheels, you need to have the rack dropping down for 12 0’clock about here (yellow arrow)
I know the photo I’m using is for a platform and not a pendulum, the striking is the same.   If you need more info just ask or if you don't understand.
Edited by oldhippy
That's a new one for me I have never seen a smooth snail wheel before. As you say it must be difficult to  get the sequence correct.
I guess I just lucked out getting to work on a clock with a smooth snail wheel.
Have you any idea how old such a clock would be? Ballpark...
It is impossible to get this kind of information in books or on the net. If not for this site there would be nothing at all.
You should write a book.
Edited by Folkvisor
Now to regulate it. Providing the springs are good this should keep very good time 1 minute in a week ether way. Once you learn about the striking, these clocks are quite easy to work on. What takes the time is the polishing, cleaning, and bluing screws.
  Happy to help anytime.
I'm still trying to get it to speed up a little more. small increments. I'm sure I'll be pretty slow when I'm 120 or so years old too.
The pins on the minute wheel aren't any too long so I have to be really careful about pulling off the minute hand or it will pull the pins away from the lifting lever. I'm not sure that I can do anything about that except making sure the pins are in place before I put the clock together.
I'm learning slowly. Someone did a lot of thinking figuring this stuff out!
Yup. I've found about wheel alignment from experience. There's lots to learn. I'd like to get a French Clock of my own to work on so I can learn more about them.
They want me to fix a grandfather clock but it doesn't look much different than my mantle clock just weights instead of springs and a moon phase 'clock'. Also,  there's lots of info on line about them...unlike French clocks.
Try and get your hands on an 17th or 18th century 8day English Longcase (grandfather) clock. They are wonderful to work on, in my time I must have restored hundreds. French carriage clocks are interesting too, because after all that cleaning, polishing and bluing screws people actually see the clock working, some do have complicated striking.
    • I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
