Fully charged movement not starting
Chopin
I had to disassemble a Seiko 4006A movement and then re-assemble it and although I cleaned it in the process I only lubricated very few parts (long story).
Everything about it functions except for the actual time keeping. It charges, it winds but it won't start. If I go into time setting mode and slowly advance the hands then it stars (seen this on other watches as well) but stops once I stop rotating the hands.
Is this simply a lack of lubrication somewhere ? If yes where as I don't want to take it all apart again, not at the moment at least. Since it's clean shouldn't it run ? Maybe not with the best accuracy but at least start...
Is there some way I can cheat this by just lubricating some parts without having to take it all apart ?
Edited by Chopin
When I stripped it apart I couldn't remove the cannon pinion and center wheel or whatever it's called on the other side.
It was tight but I didn't try to force it out. They both rotate as one as there's friction between them as if they were one part.
Is this bad ?
Is this bad ?
I’d say that may be the culprit. When you washed it, it probably wasn’t cleaned there. The force needed to spin may not be much to your finders but it’s insurmountable to the movement.
I suggest you work on removing CO and wheels associated, wash them well and try again.
Cheers
Ok so I pulled out the pinion from the center wheel. Took a bit of force. Should I just clean these 2 parts or must they be lubricated as well ? The pinion slides into the center wheel with resistance...
Yes, clean and lubricate.
Now’s a good time to check the movement. Wind up the ratchet wheel and if it goes.
What I mean to say is. The center wheel goes into the pinion. Are they supposed to move independently in some cases or are they supposed to rotate as one always ? So that's why I'm asking if I should lubricate the center wheel's "rod" that goes into the pinion.
52 minutes ago, Chopin said:
Problem solved I think... I thought the movement can be hand wound but I don't think it can. I think i was charging the alarm spring rather than the main spring... Oh dear... Lots more to learn hehe...
Chopin yes, a small dot of moebius 9010 on the cannon pinion before placing center wheel. I think all (or most) Seikos run completely on automatic wind.
J
Certainly not all or most. For example, in the current product line, only one mov.t (7S26) has no manual winding. Same in the past, only the entry level line was like that.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
