What have I bought now!
Pip
I'm not even sure myself, but I saw a listing which said it's probably an old watch timing machine, but when I looked at the pics and the French labels I thought it looked more like a watch cleaning machine. It could be of course some cobbled together Heath Robinson affair. It could be of course a complete waste of money and not likely to ever work doing whatever it was built to do again. I'll know more when it arrives! But, I thought to myself, who better to ask than the hive mind here who have had every type of contraption imaginable in their workshops at one time or another. So your starter for 10 (and lots of conferring!)...
That was my thinking Mark, but I'm often wrong! The real trouble, and maybe the members can offer some advice here, is how the hell am I going to get this one in the house without the wife noticing? I think I may end up in that big box, under my patio.
watch cleaning machine: ultrasound on/off button, wringer (dryer) on/timer/off buttons, big bottom dial is the timer.
Almost looks homemade. The attachments would be the agitators/motors to stir the solution. Do you have a better picture of the note inside the lid?
Here we are...
Here we are...
Confirms it's a cleaning machine:
Average times for small watches/clocks:
12 minutes to wash
10 minutes to rinse
5 minutes to dry
Awesome. Just have to work out if it’s alive, of if not how to revive it, and then how to use it. I’m hoping there will be a manufacturer mark somewhere and I can find a manual. Someone on another forum mentioned vibrograf but I can’t find any pics that look anything like this thing.
My word, it’s alive! Had to nip out and buy a travel plug (at work and couldn’t wait) but she powers up. There are three separate glass baths, and a spinning section which I guess is for drying, goes like the clappers when you press the right button. There are 3 what look like ultrasonic transducers with leads. Have to work out how/where to plug them in and need to pull it apart a little to follow the wiring and see if there is a makers mark on it anywhere. It’s a thing of beauty which I hope I can make useful again.
I found a makers mark, it was made (or possibly distributed?) by a French company called Sepmis S.A. If anyone has any info on them or on the beast in the thread above, even if you've just seen a similar one, I'd love to hear from you!
Phil
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
