I just completed cutting my first balance staff on a lathe. All went well on the balance/hairspring side, including undercutting and leaving enough material to make the rivet. On the roller table side however, i cut a smidgen too much. Is there any way to tighten the roller table on or di i need to cut a new staff? I thought shellac on the post would harden and keep the table on. I still need to jacott the pivots, so am i waisting my time?
a661fc5f83101f0c50e6545520c5acf2.jpg9448f018ba52bc5ef968bc5b4f4572b9.jpg3c3e89d6b4af556e1689c44da6b6107a.jpg1fa364090bf8573a1573fe5b75db3049.jpga4dc217c5419d43dca0d97c40c1efb15.jpg26d4ecb70462e727ae771970d2d81a9e.jpgb2350b43733b2e39b0354d80d4f46aa5.jpg5b4c9e301b8ee136310fa056540830ed.jpg3aa5394b4d32b37db8f3cc63b55a2a67.jpg6b9c2d27bd3c565309c52db146a43f28.jpg
  • Like 5
a661fc5f83101f0c50e6545520c5acf2.jpg&key=b63cfe8f836ff14588d3c1c5f13600455fa785f06c37f0c09647ab1e1c649c4b9448f018ba52bc5ef968bc5b4f4572b9.jpg&key=a150f0a233c327a68af670bb2cab24a85616bb20889a849a9c04e63f9794eaf13c3e89d6b4af556e1689c44da6b6107a.jpg&key=429ae1a5f0fa40a6eae5074b62565652e2e68ed4b84e84fa6bf4e9ac7577b0131fa364090bf8573a1573fe5b75db3049.jpg&key=4afb3571344584787b4c366efb07ac9f7704f5efbb9f37274e08c1d06a5749eea4dc217c5419d43dca0d97c40c1efb15.jpg&key=3d8c789ab151e06eac6e3d3e87d87c931ccade8993c72f9679c58c09ac46fd3326d4ecb70462e727ae771970d2d81a9e.jpg&key=becc5cd55829a6f37fe357ecef8f6529bc405976072628b86c948936a8f5cb5bb2350b43733b2e39b0354d80d4f46aa5.jpg&key=57c0ea5c34d285f72ebb03f87e472c7bc90d6407fcb6c3a4b8a0a3fbfc0aa46f5b4c9e301b8ee136310fa056540830ed.jpg&key=e2be288fe7c1abecd4f750c87b875a430eeff3b837579a7a603d8d7151987dbc3aa5394b4d32b37db8f3cc63b55a2a67.jpg&key=98fde1ccf489a7287489bf7be057875e66544264ac70259f3f4ef4b5c3fa8be16b9c2d27bd3c565309c52db146a43f28.jpg&key=6aa72996c4296f0d2638e431327f81b4de3bac241fb6ff01e769113f1f375b27
Amazing job and well beyond my capabilities! But I'm thinking forget the staff and concentrate on the roller table.
Try closing the hole with a suitable stake. Careful not to catch the jewel
Sent from my SM-G920F using Tapatalk
Turns out you can close the hole in a balance table using the following:
It worked. Now all i need to do is reduce the pivot size.066b34e7449d8121f48dd58f3efeb696.jpg06fd1a18ae23b55de00406c58be6b238.jpgad7a86877432a4f0e940e05c14273413.jpg
Remember, i play guitar, thus the long nails:)
It worked. Now all i need to do is reduce the pivot size.066b34e7449d8121f48dd58f3efeb696.jpg&key=2e09e2bc75e7013778e9dac2d7ced237c7beea7b6e31b66d6b374ebbc4770f7e06fd1a18ae23b55de00406c58be6b238.jpg&key=3ecc20adea0d2bb606e715d3d0865230a4b21cdacec9e042e6abe25a664672b1ad7a86877432a4f0e940e05c14273413.jpg&key=88f2283ef9e039d019b8bbe99c10d8596351212d1233fb0de3e4646d9d94f784
Excellent, is that a reverso staking set and you've used two stakes, the bottom being solid flat. Or is it a traditional stump ?
Sent from my SM-T585 using Tapatalk
You are correct. Flat Stake on bottom and round one on the top. Took a bit of pounding as well.
You have achieved what is probably the hardest thing to make in in horology. You could have used lock tight; there are many types such as a thread lock tight, many people who make parts on lathes use it.
When using a punch you have to be very careful not to split the roller.
Good advice. I'm going to cut a second balance staff this week. Finishing the pivots tonight, as my 4 new 0.2 and 0.4 round and flat carbide gravers are coming in tonight and a really need that round shape to finish the cone on the pivot.
Sent from my GT-N5110 using Tapatalk
I have the two sets of videos on using a lathe and I have the bible book on lathes "modern watchmakers lathe and how to use it" as well as practical watch repair and many other books. I have watched and read it all so my brain has the knowledge. Then I practiced for a week (4 hours or so) on brass stock. I then cot a stem using blue steel. And then I tackled the balance staff; taking my time and measuring and fitting as I built the part. I have learned about taking it slow as I over cut the roller table shaft a bit....good lesson. Next staff will be a lot better.
Are you doing anything different this time?
I am taking more time to taper the shaft so I don’t over cut any part (like the roller table last time). I also got four 0.2 and 0.4 square and round carbide gravers to finish the pivot better. I also started with 1.97 mm blue steel this time, so less cutting to the first diameter.
I am going to cut the staff with the stock attached and only leaving the Roller Table side pivot to complete. So i will complete one pivot before cutting off the part and reattaching to finish the roller side. I also purchased a triangle shaped Arkansas stone to finish the pivots, just prior to burnishing.
Finished the pivot end. Very tough work. Graved it down to .15 and used two different stones to get it to .13, same as the original.559327fb6d887cc79d4a1632f28523a7.jpgbd8c1e3ac0fb1769280c2070430fd2ad.jpg04a568b0c85968c006836dd026580350.jpg
Finished the pivot end. Very tough work. Graved it down to .15 and used two different stones to get it to .13, same as the original.559327fb6d887cc79d4a1632f28523a7.jpg&key=20846ef284c9b470438e134c88636f9b3c84bcd42a2b18186e29a66bc727e075bd8c1e3ac0fb1769280c2070430fd2ad.jpg&key=8f2cfbbd3abeae843bca0efa49b62373f476ba4525c1cfc3aec83d986b5816af04a568b0c85968c006836dd026580350.jpg&key=e7043dc2f2eb99b1650c86fcf427fd646462c6461ad580ff7ab1a28e70a8f9bc
Amazing job
Riveted on the balance staff. Had to pound a bit with the dome stake. Needed a tighter fit on the staff. Took off a bit too much metal. But alas, its on and ready to fit and trim down the length of the pivots.654a423e3132887c814ab662a875072f.jpga9378da44ce367f8bde6e7841e4d16f6.jpg
What you did ~works~ in an <insert zenophobic ethnic slur here> worker kind of way. If you blow a measurement on a staff, only solution is to start again. What you did would work on a clock, but centricity on a watch balance is too critical. By tightening the roller table in a staking set you've mangled the center and I'd be surprised if you got that thing even well poised. Like I said though, it will ~work~ but you've just forfeited precision and introduced positional timing variability.
It will cause poor time keeping in a clock, so in fact it will not work.
My experience with this is mainly pocket watches, in particular, "Waltham" The roller table is a friction fit and once removed for any reason can, on reassembly become loose, especially if removed several times. Reducing the bore size of the roller table is a method of rectification and would have Zero effect on the balance poise.
Also when fitting a new staff; even a factory manufactured one, on these old watches it is quite common to secure the balance wheel to the shaft in the way Jdrichard has done. Though a suitable hollow stump under the wheel arm is advisable, to avoid distortion to the balance wheel itself.
Digg is correct. This is a riveted staff so there is only one way to put it on. It is NOT a friction fit staff. I could have cut another staff, however, the text books do state that you can adjust the hole on the roller table the way i did it.
Before fitting the hairspring, always a good idea to check the balance wheel is running true. Riveting on these split balance wheels can lift an arm sometimes if your unlucky. And some minor adjustment to re-true the balance may be necessary
