New to the luxury watch world
Aidan
Hi there I have been watching your videos for a few days now the reason is I was finally able after 20
years of wanting one I bought a Rolex I went for the  milgauss I would like your thoughts on this watch and have you any
footage on servicing one please thank you
aidan featherstone
I am a lover of Rolex having owned a couple so has my wife. The build quality is excellent and providing they are serviced they will last a life time. The "milgauss" is a new one for me but looks great. The movement fitted is a 3131 and looking at it it is very similar to the 3135 which I have serviced. I have not found any vids or walk throughs on how to service the 3131.
PS welcome to the forum.
I have had quite a few Rolex watches in my time Starting with a 1970's Submariner a Root beer GMT a Blue face Bi-metal Submariner but have sold them all, I will be getting another quite soon I'm plumping for a Explorer 2 42 mm as I like the larger case, they are without doubt great watches.
There are things I didnt like about Rolex the bracelets on the older watches where quite laughable I thought for a luxury watch the pressed out clasps where terrible but the newer models are now fitted with a much more solid arrangement as you will no doubt know from your new watch, The bi-metal sub I had all the gold centre links where hollow which I thought rather cheap considering the price difference between the standard steel model and the bi-metal £1,600 more at the time this has been rectified with newer models now having solid middle links but at 3x the price I paid.
I would not service one myself Rolex servicing is second to non in the industry I had my bi-metal sub serviced it was a 5 week turnaround  which is excellent for a large company, and it came back as new they really do a fantastic job of case refinishing  at Rolex  I have had problems with both Omega And Jaeger lecoultre servicing in the past and would avoid them at all costs the Jaeger took 6 months to be returned .
You have a great watch in the Milgauss
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
