Hi everyone,
I would need a new barrel complete for a Orator Precision pocket watch from the 40's. I never had to order such a movement part before, could anyone tell me how/where to select/order this ?
Thank you,
Cedric.
First you need the cal number. You order barrel complete, which will include barrel, arbor and cap, you will need to order the spring separately. Google watch material suppliers in your country, which I think you, are in Belgium. As it is quite old you might not be able to acquire one. If that is the case, you might be able to obtain the parts on ebay or an old movement. Someone on here might have the parts. Tell me why you need the complete barrel.  You could try suppliers out side Belgium those that sell all over the world.
Thank you for your answer. It is an Orator calibre 18.280. To my knowledge, they do not supply parts anymore.
I could of course look for second hand movements, but they are rare and pretty expensive (as of 150 EUR).
Actually something very bad happened when I tried to unscrew the ratchet wheel...please see picture.
Hence I thought purchasing a compatible modern complete barrel with spring would be a convenient option.
You may just need a new arbor rather than a whole barrel. You may get lucky finding a new arbor and making a new one is certainly within the ability of a good watchmaker.
I just checked Cousins and they have no parts for that calibre, ebay may be your best chance
Thank you guys, I'll check the internet for opportunities and will ask a quote to a watchmaker in parallel !
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
