Have you tried ebay or Citizen.
I have tried eBay with no luck. Would need to buy a used watch for a button and they run around 150! I will keep hunting.
You might be lucky to find one at Cousins who supply various buttons by size.
Did not try cousins yet but will, thanks.
You might find another model Citizen of the same era uses the same part and is less than 150 gbp!
Cheers Neil
You may be able to buy the part, but will need the part number.
Starting point is the complete reference number. This will be on the case back. The first 4 digits are the movement number then you get the case number.
Sometimes you will get lucky and find that Boley, Jules Borel or Cousins lists the parts for that case. For example http://boley.de/en/case-parts/citizen/15756?l=7&q=Q01661, although in this case only one pusher type is listed.
Once you have the part number you then need to try Jules Borel, Cousins, Esslinger, eBay, etc to see if you can find one.
You may find someone on the Seiko and Citizen Watch Forum who can look this up in a catalogue if you are still struggling.
Very good advice, thanks and I will try your suggestions
