Yes I believe you will. Apparently there is another thin spring under the day ring, so be prepared for that to fall out of position. Thinking back, I don't know that I have ever done the M33 Day/Date automatic to see how that part is arranged. I have only worked on the M32 date version.
Wow. Thank you both very much, I couldn't have asked for better help.
Now one question, to tighten the screw I have to remove the day and date wheels, right?
Newbie anxiety. 😁
Regards Vasco
Hi Team. Got this on the bench with no idea of maker. Swiss 21J Lever. 40 mm dia . Hallmarks suggest 1928 era. Lovely 9kt Half Hunter in fine condition. Hours on Ranfft have only produced eye strain. No signatures anywhere. Plain Dial. Sub Seconds.
