Charity Shops, Worthwhile?
It's always worth a look, you never know what will turn up. I managed to replace my fathers old silver fusee watch many years ago with an Identical one from a charity shop. I threw his away when I was seven because I was too frightened that he would find out that I broke the hands off. I was forty seven when I replaced it and told him the story!
I found (or rather my wife found) a Mint copy of "Cooksey Shugart Complete Watches" in a charity shop in Stratford on Avon for the princely price of £1.95 (plus a small additional donation to allay feelings of guilt at getting it so cheap).  I always have a look at the books despite being an avid kindle user.  Have seen a few watches but up to now, none I would want to toy with, but you never can tell what the future holds.
    • Maybe I'm over simplifying this and I'm a little late to the discussion, but just by my looking at oil when I use it on a treated cap jewel  the oil stays in one nice bubble, but when I don't it spreads out to the edges of the jewel. I'm not sure (but could well be wrong) but the analogy of a waxed car and rain is accurate in this case, the wax is very hydrophobic and repels the water, however, the process epilame works by is a different physical process based upon cohesion/adhesion (oleophilic) not repulsion (oleophobic)  at least as far as I have read/observed. If one were to use a oleophobic substance equivalent to wax (hydrophobic) then one would need to create a donut shape to fence in the oil, however if one used such a strategy with a epilame which is oleophilic then the oil would sit on the ring of the donut and not in the 'donut hole', exactly where you don't want it. Even is the oil is smeared then the oleophilic epilame should pull it back to the center (see diagram below). Reference
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
