Shock Spring for Bulova 11 AL
Hey all. New to the forum and to watch repair.
I'm working on reviving a 1965 Bulova 11 AL. It was not running when I got it, and after a clean and oil, it's now running pretty strong*. However, in the process of stripping it down, I did break the shock spring on the mainplate. I was lucky enough to find a replacement on eBay, which is on its way, but as I did a test on a similar one, I ended up breaking it on removal. So, I'm obviously not very good with the things. I've attached photos of where the eventual one will go, as well as a photo of what I bought (spring in tact).
Any advice on the best way to remove and then install these? Any help is appreciated.
* I say running strong, only when facing up, as the lack of stone (which I still have) on the other side keeps the balance from spinning when upside down.
Thanks,
Seth
You can buy proper tools for this type of work. If you have a good cleaning machine in many cases, it is not necessary to take them apart.
I expect some on here will be very eager to criticise my info.   :D
Thanks OH and Rogart63. I think the decision I will have to make is whether it's easier/safer to try to remove the spring from the donor mainplate and then install it in my watch, or just swap everything over to the donor. I'd prefer to just swap the spring, but after breaking two of them, I'm a little nervous.
Thanks for the other thread. I did indeed see that, it just didn't give any master tips for removal. Probably because there aren't any master tips. But the covering in film/rodico for installation is helpful, as is your graphic for removal.
As for cleaning, I can't afford the space or money for a cleaner, so am doing things by hand. Hopefully next time I can just get the stone out for cleaning without breaking the spring or needing to remove it completely, which is obviously a pain.
I wanted to follow up that I successfully removed the spring from the donor plate and got it installed in my Bulova. It's now running whichever way it's facing and I'm quite pleased. Thanks for the help here. I also found this video:
https://www.youtube.com/watch?v=HiAh4TkN25s
Which was a huge help, mostly in giving me the confidence that it wasn't impossible. It definitely was trickier for me, but I got it in:
I did employ the technique that I found elsewhere here to lay a layer of cling wrap between me and the movement to prevent a fly away spring. It ended up not being necessary, but made me feel a lot more confident.
Well done Seth. Trading via this site is not permitted, but if you are in the uk and advertise the remainder of your donor movement on ebay, you might find that someone would buy it to obtain a clutch wheel :-)
Is it a trade if I just give it to you? DM me your address if that's not a violation. Unfortunately, however, I'm in the U.S., so you'll have to wait for me to get an international stamp, plus travel time.
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
