Here is a photo of the opening in question:IMG_0374.thumb.JPG.706c6bce8521f6c22cd1f22f18d2ec8e.JPG
I don't think that hole has anything to do with it because the teeth are on the top edge, if that is the case just lock the wheels up and remove the barrel to take the power away.
There is a small pin in the opening that raises and lowers when the watch is wound so it must be the click. But I have no idea how it can be disengaged to let down the mainspring. I've tried small screwdrivers and very fine strong tweezers and no luck.
I actually stopped the wheels with Rodico and removed the barrel plate to have a better look but the barrel wheel is in the road so it is impossible to see underneath it without removing all the wheels and I don't want to do that unless the power is let down.
It's a bit of a conundrum...
Any ideas??
Any ideas??
Is the power let down or don't you know?
It isn't let down entirely because the watch starts working from time to time.
It was working fine and kept good time. It suddenly didn't work; no idea what happened.
What I would do is lock the gear train up remove the balance, remove the pallet and let it power down on its own then strip it
I presume the pin is inside the whole you identified. The watch manufacturer would not have made the whole without it serving a purpose. Perhaps you are looking at the edge of the click. If so you just hold it back while the barrel unwinds.
If you go about it this way make sure you have oiled all pivots. Do this at your own risk.
I'm going to try to release the click with the a small screwdriver instead.
I wonder why anyone use this system. Maybe it was exclusivity or something but it sure doesn't make a watch repairer's life very easy.
I'm working on a watch with no jewels anywhere as well. I wonder what kind of lubricaion one uses on that.
Your Waltham has a lever release. You're not seeing it in its entirely. You need to remove the split dust cover first. Which is located around the middle of the movement. Push the lever up by the stem hole and gently rotate the first part of the dust cover and gently easing away from the movement. Then remove the other half.
Once this is done push on the lever located by the mainspring barrel but remove the balance wheel first.
Sent from my SM-T585 using Tapatalk
On examining the balance, while attempting to remove it, I found a piece of crap on one of the escape wheel teeth. I carefully removed it and eureka! The watch now is running again.
I'll monitor it for a while but I think I've solved the problem. No idea where the piece of whatever came from...
I may still need to mess with the winding mechanism...
I was wondering if it's OK to remove the balance cock with the wheel is attached.
And I am wondering why it is necessary to remove the balance before messing about with letting down the mainspring.
Simple answer is you don't need to remove the balance. Ensure you control the let down of the mainspring. If the movement has a Swiss pallet fork , removing the balance first will not release the mainspring but do not remove the fork with any tension left on the spring. Parts for Walthams can still be procured on for example ebay but balance assembly in good condition are gold dust.
Your movement is a 3/4 plate but seems to be fitted with the model 1883 type balance. If you can I suggest you remove the whole assembly. If not, there is a small screw opposite the hairspring stud. Loosen it but not too much so it can fall out. Then once the stud is pushed out, you can remove the bridge and then wheel. Remember to tighten that little screw whilst the bridge is out so it doesn't get lost.
If you try to reassemble in the same way on the movement, getting that little stud back in, is a nightmare. It's far easier to reassemble outside the movement.
Hi
I've had previous experience with those little stud screws.
The third photo, posted 14 June, shows a small lever in an indentation. I've discovered that this lever pulls out.
Any idea what that does?
I've had the barrel plate off but can see precious little that way.
Always interesting stuff!
Dave
Hi
Dave
It's what you pull out when you run the watch out of the case,if you don't it looses time.
I disassembled the watch. It so happens that the photo I posted on June 15th shows the hole that is the access to the click. It has a small cleat on it that allows it to be moved away from the cogs in order to wind down the watch.
I took off the balance bridge and found that there was no pressure on the pallet fork so I dismantled the thing.
But, there is a bonus! The pallet fork safety has an S-shaped safety that matches another Waltham I was working on. I thought this was because it was bent but it is supposed to be that way.
So, now it may be possible for me to repair the other watch. It just needs a hairspring and that may be possible to replace.
Live and learn...
Dave
    • It was first a brand, but became a standardized style. So you will find some older lathes actually marked "Webster Whitcomb" and many other makers who built WW lathes conforming to the same dimensions for spindle height, bed shape, attachment setup, collet size and design. https://www.lathes.co.uk/derbyshire/ So when someone mentions a WW lathe today, they are talking about any lathe that conforms to the standard, which could be a 110 year old American made lathe or a European made lathe from the 1960s or something else.
    • Hi guys, just a little thank you for the CLOCKBARN site in America.  I purchased a TIMETRAX APMLIFIER to help with setting clocks in beat from CLOCKBARN it arrived on time and when tested worked ok.  A week later I had occasion to need it again, this time nothing the unit was dead. Checked out batteries , probes etc , nothing.    I messaged CLOCKBARN  to this effect.  I got a prompt reply that he would send a replacement which duly arrived today and having tested it it’s ok.  So I can recommend the site should you need to use it. The person,persons who run it are genuine guys.  So thank you CLOCKBARN  for your excellent service.
    • Hi there! You have learned how professional watchmakers feel about Timex. It is very difficult to find one willing to work on them, for a few reasons: 1) a lot of them wrongly believe Timex cannot be serviced, are riveted together. This is a myth. 2) when serviced, they still cannot meet the performance standards of jeweled mechanical watches (-20sec/day is good enough for a Timex) 3) customers are unwilling to pay the watchmaker's hourly bench rates because the watches are worth very little The service manual for the M33 is available at https://heritage1854.com/m33 but you also need the M32 and M31 manuals because they build on each other (31 is the base, 32 has date, 33 has day and date) https://heritage1854.com/m31 https://heritage1854.com/m32 A stuck date changeover can be due to a missing, bent or broken detent spring (part 2576 in the manual) or the date wheel (2556) got stuck or separated from its post, or maybe disengaged from the hour wheel. With a little confidence, these are not difficult to repair and parts are pretty much interchangeable with any other Timex from the same era having the same features. So it is very easy to find inexpensive spares in the form of junk watches (don't bother trying to search for individual spare parts). My recommendation would be to find a junk Timex with an M25 (older manual wind with date) and practice a little with it. Follow the service manual from the same website. The automatics are a bit more difficult to work on but once you get a feel for how they fit together, you can make an attempt at your automatic and you would be able to use many spare parts from the M25 if necessary. To work with most Timex movements, you do not need a lot of tools. Just one screwdriver, 1.4mm is a good size, tweezers, and hand levers to remove the hands plus hand pusher tools to replace them. Of course if you want to do a full cleaning and restoration more is needed. But to get it apart and diagnose, only minimal tools.
    • I do indeed have some programming and electronics know-how. 3 decades writing code for a living, and playing with microcontrollers as a hobby. 🙂 It helps with my actual living of being a voice actor because I can maintain my own equipment- no one around to replace the caps or the tube in an obscure botique mic that isn't made or supported any longer. Also saves money maintaining and cleaning my own interfaces and mixers when they develop problems in the faders and such. That said... I do have a question that, I'm sure, will betray my ignorance about certain areas that I have yet to fill in. I understand a "WW" lathe is a "Webster Whitcomb", but from what I understand that is a style of lathe and not a brand, correct? If someone would be willing to clarify and maybe expand on the terminology, it would be helpful so I can better understand the advice being given and know what I need to look into to further my knowledge. For example, a Sherline mill would appear to be either a separate piece of gear or an attachment/expansion to their smaller lathe. When you say you have a WW lathe and a sherline mill, can you say exactly what devices you have? Thank you! (I just realized I have a few Raspberry Pis and some Arduinos of various form factors around here I could probably put to good use in a scenario like you describe above).
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
