Seiko partial service (not a question)
I'm seeing more and more of these, 6R15s almost new which exhibit a poor pattern or performance. This one, manuf. Apr. '14 was spinning 210 deg. face up, dropping to about 170 in other positions. What I do in these cases is let them wind down (to avoid removing the auto bridge), remove balance jewels, balance and pallet fork. Leave these parts 5 minutes in rectified gasoline (got in 1L bottle from an otherwise useless local supplier), applied 9010 to the stones, and put it back together. Takes less than 30 minutes. Picture taken before regulation.
Edited by jdm
Very interesting. Thank you for sharing.
Im not sure of the specs for the modern seikos as all my experience is based on 6139 and 6138. The amplitude on those appears to be lower than expected in general, which is something most watchmakers now expect and tolerate.
What does jump in what you're saying is the significant drop to 170 in VPs. My young experience would have me worry about endshakes or pivot/jewel issues.
So, after cleaning and oiling the amps remained reasonable?
Thanks again for sharing.
Happy Sunday!
Yes, as in picture.
pallet fork stones left unlubricated, or?
As mentioned: "remove balance jewels, balance and pallet fork. Applied 9010 to the (related) stones". Nothing else.
Edited by jdm
Not too familiar with these watches as (1) I live mostly in 'banger' territory! (2) I dislike the 'square' anti-shock springs and (3)The finishing is unpleasant to my eye.
Nonetheless they seem to have good reviews and I'm surprised that they need attention at such a young age! Where are these made? In Singapore?
Anil
Not sure what do you mean by that. 6R15 based Seiko cost easily $500 and their owners usually take good care of them.
Actually the Seiko Diashock system is one of the best ever made, with possibly millions of units produced. Easy to work with and highly effective.
Finishing is simple but very nice. Cotes de Tokio on the rotor,  beveled balance cock, and few more details.
Made in Japan. The 6R15 is primarily a mov.t for JDM watches.
Sorry, still confused, you said you soaked the parts in a gasoline, so if the same is true of the pallet fork, then no oil will remain on that (and at least theoretically there wont be any on the escape wheel) and I've not heard of a pallet fork/escape wheel being lubricated with 9010. Can you clarify?
I'd be interested to know that it apparently runs well afterwards, in either case, since seiko service sheets typically instruct lubricating the exit and entrance stone.
Edited by Ishima
Sorry, still confused, you said you soaked the parts in a gasoline, so if the same is true of the pallet fork, then no oil will remain on that (and at least theoretically there wont be any on the escape wheel) and I've not heard of the pallet fork/escape wheel being lubricated with 9010. Can you clarify?
As asked and answered before already: I do lubricate the stones of the pallet fork with with a very small amount of 9010, which is what Seiko recommends, they call it "Moebius A". Attached service sheet.
6R15B.pdf
Hi JDM,
by living in 'banger' territory I meant that I usually work with beat-up 6119s, 7006/9s, 6309 and sometimes 7s26/36. As you rightly said, these (6rxx and similar) watches are priced higher and the owners would send them to the Seiko agent for attention. It will take a while for them to get to the stage where I can get my grubby hands on them!
I dont have an issue with the diashock system but more with the square springs that started with the 7S26. The older 3 pointed ones I can get back in place with a rusty nail but the square ones are a pain, especially the smaller ones on the train wheels.
WRT to the finishing, well the pic you posted of the balance wheel cock says it all. Is it acceptable?..yes in the sense that it doesn't affect the efficiency of the watch which works extremely well. But I prefer the finishing of the older movements. Additionally the pressed in posts which Seiko started using in the 7s26 really bugs me.
It comes down to personal preference.
cheers
Anilv
I hear this complain a lot, but honestly I find these spring quite easy to deal with.
For the balance ones there is two methods, first the "tweezers only" one where you keep a thin finger of rodico over it and use the tweezers to put it in place. This methods require moderate manual skills, so I decided to document the other, which is even easier.
File a pegwood to the shape below. If you don't have pegwood, use a toothpick, brochette stick, or anything like that. The outer diameter must just go inside the jewel setting, then carve the inside with a 1mm drill bit.
The rest is intuitive. Note how the spring is very off-center before applying the stick, but the soft wood easily takes care of that.
And for the small ones in the train t's even simpler, don't bother removing them, wash the plate, oil the related pivots, and enjoy the good results.
I don't really think you can find a better finished mov.t at this price point, except possibly on some Seagull. I don't see anything wrong or ugly in the pressed posts.
Edited by jdm
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
