Bargain Waterproof Tester.
I've just taken delivery of a Waterproof Tester from China. It took nine days from placing the order to recieving it. I have given it a good look over and checked it for holding pressure, and it is a very well made piece of kit for the money. Import charges worked out at £23.76 making the overall cost £150.48
http://www.ebay.co.uk/itm/271225089197?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Nice Geo!
I bought the same unit about 6 months ago off eBay!
I've used it a few times and it seems to do what it is supposed to do! Also, It's a pretty substantial piece as well, heavy!
Does this unit have the connection on the back for use with a vacuum pump?
Hi guys, may I ask what range of pressures it measures? Thanks.
Mine is packed up for the big move, but if I remember correctly, the gauge goes up to 6 atm, but it should only be tested to 5 atm.
That's what I thought, most of them don't go near 10 atm (regardless of manufacturer), but I guess 5 is just fine (at 50 m/165 ft depth) and they look sturdy and well made. It is a great deal at that price vs. the 5 atm bergeon at almost $1000.
I'm just looking for a break in prices for the 10 atm ones since I'm working on divers. If I manage to restore them to original specs as per their writing on the dial, I may need to test for a range from 150 - 300 ft. depending on the model.
A lot of these tools from China get dished by the purists but they seem to be coming up trumps and with really competitive prices.
My brother - in - law a couple of years ago purchased a Chinese watchmakers lathe.
I just can,t fault it and he loves it.
It certainly is as good as my Swiss Star lathe.
    • $12.50 + $6.00 shipping I do enjoy collecting ladies watches.
    • What voltage are you feeding it?
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
