Hi, I am looking for advice about Seiko 6119 6400, to cut a long story short I am trying to replace the winding stem and crown and have hit a problem. When I put the stem into the watch it turns the inner bezel/dial but won't stay in. I have noticed the little button that you press to release the stem is stuck down,,, I think this is the problem? I have dropped a little watch oil down the hole hoping it would pop out. Has anyone any advice? I don't really wish to dismantle the watch as it is running sweetly and I am very inexperienced with watches. Many thanks in advance. Johnnie
Hi Johnnie ,
Hopefully you didn't inadvertently knock the yoke off of the groove on the clutch wheel . If the little button is stuck down , that means that the setting lever is not seated properly and not allowing the small nub on the setting lever to engage the grove on the setm.
This happens sometimes when replacing the stem .  First thing is to use the stem and crown or a small screwdriver in the stem hole to gently wiggle the parts into alignment . Doing this will work more often then not .
If this doesn't do the trick you have to remove the dial to access the setting / winding mechinism to align the parts ,...usually the yoke back into the clutch groove as I previously mentioned . Your watch is a bit more complacated because of the gear that turns the inner rotating bezel .
Attached is the PDF tech sheet for the Seiko 6106 , which is the base movement for the 6119 . You can see the parts I'm talking about ....Good Luck....
6106A.pdf
Edited by ricardopalamino
Hi Ricardo, Thank you very much for the advice and the diagrams, I am sure I will be able to sort it out now. Thanking you once again. Regards Johnnie
Hi Vinn, thank you for the advice, I will remember it. I know very little about the mechanics of watches and fully expected to make many mistakes and expect to make many more. But, every time I mess up I learn something new. This is a fantastic forum with many knowledgeable people on it and I am so pleased to have found it. Thanks again, Johnnie
Johnnie; Le Carl wrote a  book on "watch repairing' - old, basic  but very good. ( one of many good picture books).  vin
Quote
Hi Vin, advice taken, have just ordered "practical watch repairing" by Donald de Carle! I think that's the book you mean, I have taken the dial off the watch as a jiggle didn't sort the problem, I had pushed the button thing out, all back in now but winding stem still pulls out,, not as easy as it did do. It's like it's now catching but not catching enough if that makes sense? Johnnie
Is the finger of the setting lever spring broken off ?
It keeps the pressure on the setting lever that holds if firmly in place and provides the clicks for positive setting positions...[ 1st position , 2nd position for setting . It is a common problem tor these delicate fingers to get broken off when refitting . They are necessary for proper setting operation.
59062061f38f6_ScreenShot2017-04-30at7_26_45AM.thumb.png.041f3814ac98ff27e3517407c573e005.png
5906207520acb_ScreenShot2017-04-30at7_27_37AM.png.59bd5bd2d529f5f2612d485697994e2a.png
Hi Ricardo, I have just checked,, everything is as it should be, nothing broken. But in checking I realised I had positioned it wrong! Have just positioned things as they should have been and now the winding stem is fitted and has clicked into position perfectly, thank you for the "clue" and the diagram. Johnnie
Indeed so Ricardo, I can't tell you how pleased I am. I know to most people on this forum it's not very much, but to me it's great, can't wait for tomorrow so I can finish it. I have to trim the stem next and fit the strap then it will look good. Bought some lock and seal so crown doesn't undo. Johnnie
Use patience when you trim the stem . You have the added gear and spring ,[I think ] , so don't cut it too short . Better a bit long and sneak up to the right length with a fine jewelers file .
Yes, I intend to sneak up on it bit by bit until it's exactly right! Normally I am not used to such tiny tolerances but I am enjoying it. Johnnie
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
