Hi
I am working on a Hamilton pocket watch with a broken mainspring. I am wondering how to measure the spring so that I can get a replacement.
I'd imagine length, width and perhaps thickness as well as barrel diameter.
Any help I can get is welcome.
Dave
Hi Dave,
To save me posting the same thing again, see here.
If you know the movement type, you can use the search tools on Cousins website, and they also have the GR catalogue scanned in there.
You'll need the height, thickness and length of the spring plus the inside diameter of the mainspring barrel.
Once you know this you can go to a site like Cousins UK (other parts suppliers are available!) to see if you can find a match: https://www.cousinsuk.com/category/mainsprings-by-size-watch-pocket
Mark has actually done a nice informative video available at: https://www.youtube.com/watch?v=CZfFkv0FLX4
Edit: Stuart ... we must have been writing a reply at pretty much the same time as yours only appeared once I'd posted mine! :-)
Edited by WatchMaker
28 minutes ago, StuartBaker104 said:
Hi Dave,
If you put the model no or serial numbers down I will look in my book and give you all the dimensions.....
Thank you all for your help.
I'll have a look at the Waltham reply.
It is a Hamilton 925 and I've found a short video regarding replacing the pallet fork but it would be nice if there was a complete strip-down video of it somewhere. I'm not sure how I should proceed with removing the balance assembly for one thing. The watch need to be dismantled so that it can be cleaned and lubricated.
Again, thank you for your help.
Dave
Dave, if you have snags finding the exact size mainspring as I did on an old pocketwatch not so long ago I was given some advice of going abit smaller on different measurements of the spring, I will try to find the post as it was on this forum, basically I think I went a tad smaller on one measurement and although not the exact size works perfectly.
Good to know, thank you. As long as the T ends fit I guess the spring could be shorter.
I was wondering about lubricants as well. Would D5 and grease used for a wrist watch work? Can the train pivots be lubricated with 9020 or even 9010 and the pallet jewels/escape wheel with something even less viscous?
I don't think the watch will be used every day so I don't think it'll get high wear.
Dave
Hi Stuart
Thank you for the links. Basically, the higher the friction the thicker the lubricant.
I was told clock oil and grease should be used for pocket watches but I don't particularly like that idea.
Glad Valdbergsmassoafton!
Dave
It's a bit tricky getting the pallet fork into the opening where it engages with the balance wheel.
I lucked out with all the other wheels. All the pivots went in their respective holes. One good thing is that there is lots of room to fiddle with things and I got a good tip regarding making a small forked tool with pegwood to guide the pivots.
I ordered the spring - just waiting for it. I look forward to having it going again.
Dave
Bit confused there... you should fit the pallet fork before the balance wheel.
I may be teaching grandma to suck eggs but... To be sure that everything is running freely, normally you would fit each wheel on its own and make sure it turns smoothly, then fit the train wheels together with the barrel. With one click on the mainspring you should see the train wheels turn freely and then recoil - again this tells you that everything is running freely. Then fit the pallet fork and give the mainspring a turn... the pallet should flick back and forth with a small nudge.  When you fit the balance, align the roller jewel with the pallet fork, then align the balance cock with its alignment pins. The balance should spring in to life and then you will know that you are not doing any dmaage as you tighten the balance cock screw.
Yup, the pallet fork works fine. I'm going to wait on putting the balance on until after I fit the spring; on order. It is pretty vulnerable sticking up the way it does.
There is a good video on YouTube re the Hamilton 925. There is a neat way of replacing the pallet fork in the video using painter's tape.
Just go to the YouTube site and put this suffix in after com.
I put it together the other way around because that's how someone taught me to do it. I think this is a good way to do it as well but both ways need a little patience lining things up.
/watch?v=81yo_cwdBkU
I like the wooden screwdrivers he uses in the video :unsure: The other pegwood tools look handy, too.
Yes, I made a pegwood screwdriver as well; since I was working on a friend's watch and didn't want to scratch it.
I also like the idea of backing off a screw until it clicks into place. I've always done that with screws that go into wood on a piano but I've never done it on a watch. I think it's a good idea for larger screws but, with screws as big as a speck of dust, I'm just glad to get them in...
I'm still waiting for a mainspring for it but the watch works if you put pressure on the wheel so I just hope I can fit a new mainspring without incident. I've never done it before...
On ‎28‎/‎04‎/‎2017 at 6:45 PM, Folkvisor said:
Hi
Dave
sorry Dave for taking so long but I have been away
WP_20170504_21_07_43_Pro.thumb.jpg.6ba26c381d1e71d46408184199686cf5.jpgWP_20170504_21_08_15_Pro.thumb.jpg.e1f2594aa57d745223ea64cf6fbf4564.jpgWP_20170504_21_10_20_Pro.thumb.jpg.2d9197dc6785483ca4a50313c96bca38.jpg
is this any use to you
cheers kaz
8 minutes ago, Folkvisor said:
Hi
Thank you for this. I've ordered a spring - hopefully it fits.
Dave
No problem
I got the spring but the cleat on the barrel arbour is being stubborn about grabbing the end of the spring. I am bending the spring slightly so it will 'hug' the arbour and I think I've almost got it convinced.
Also, it looks like I may need to file the hole in the top plate of the barrel a little so that the T will fit better.
Replacing the barrel wheel is going to be fun too...
Always something but never boring.
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
